If I understand correctly what you are asking about is running three instances of openHAB, one production, one for test, and one for development.
Personally, I think the test instance is unnecessary in all circumstances. Given that it’s just you doing the development, the amount of risk of failure that is mitigated by having a dedicated test environment is not worth the extra cost and effort required to build a test environment. Instead do your testing in development and mitigate any problems by taking backups before deploying to production so you can roll back if required.
For day-to-day development of automations and such I don’t see the cost and effort of maintaining separate production and development systems being worth the risk mitigation it buys.
A big problem you will encounter is that many technologies require access to physical devices and only one instance of OH at a time can access the physical hardware (e.g. a Zigbee Coordinator). So you will either have to wait to test that stuff until you deploy into production or you will have to do periods of processing. In either case that all but destroys the whole purpose of maintaining a separate production system because either you’ll have to be doing tests live on production or you’ll have to take production down to do testing and development.
Therefore if you have a dependency on physical hardware I just don’t see how maintaining separate production and development environments mitigates enough risk to justify the considerable cost and effort to set up and maintain. Instead, use a well defined and tested backup and restore and be diligent about backing up and restoring. In addition, use a source control system like git that allows the creation of and easily switching between branches.
If you do not have a dependency on physical hardware then it becomes much easier. You can usually indeed run the two instances at the same time as long as the APIs being interacted with allow more than one client at a time. Though even there you will need to build into the system some way to keep the development automations from interacting with the “real” physical devices. If it does then once again that defeats the purpose of maintaining a production system. But then if you don’t actually interact with the real devices, how do you know that what you are doing actually works? And we are right back to the same place where you need to run periods of processing which defeats the whole point of having a production system.
So again, I don’t see that the cost and effort is worth while and again recommend a good backup and restore procedure and the use of source control with branching support instead. To really have a true development environment, you’d have to have a separate set of all your devices that only exist in that development environment so what you do in development doesn’t impact production which can be a considerable cost.
However, I do see a lot of value in running and maintaining separate instances of openHAB during a migration between versions and have actually done this myself. How I did most recently when migrating from OH 2.5 to 3.0 is as follows.
Background:
- I run everything on VMs on a server class machine
- All services are running in Docker containers
- All machines and Docker containers are installed and configured using Ansible
- My approach to home automation is just that, automation, not control; this means that disruptions in functionality on the UIs are not a problem for me.
- I use git to source control my configs.
- I kept my old OH 2.5 container running in place and unchanged to start.
- I started up a new OH 3 container on a different VM to start transitioning to the new instance.
- Little by little I moved rules and other configuration from the OH 2.5 to OH 3 instance. In this case I also moved from text based configs to managed configs so ultimately I needed to recreate most things. If one sticks with text based configs, this would be copying the files over one by one and testing things out. I moved the hardware dependent stuff over last.
- Once everything was moved from the OH 2.5 to the OH 3 container I shutdown the 2.5 instance and used Ansible to spin up the OH 3 instance on the production VM and took down the development instance on the other machine.
Alternatives:
If you don’t have separate VMs, Docker makes it relatively easy to do this all on one machine. However you’ll have to expose the ports individually and map them to alternative ports so it doesn’t interfere with the production instance. If you have technologies that use things like network wide broadcasts or DHCP listening or the like that might break if you don’t use --net=host and you’ll have to wait until you get to production to test that stuff.
You can also do it all on one machine using periods of processing. While working on the development instance you’ll have to shut down the production instance. When done for the day, shut down the development instance and restart production. When done with development, delete the old production and your development folders become production.
If after all this you determine that it is worth while maintaining three separate instances then to move configs from one instance to the next you just take a copy of all the volumes you’ve mounted to the container from one machine to the next. If not using containers, you can just use openhab-cli backup and restore to move the configs from one machine to the next.
