I would like to use the same HABPanel panel configuration for displays in different rooms, i.e. the only difference could be the room temperature where the display is located.
Is there a way to identify the device / display in a custom widget?
HABPanel uses AngularJS.
Using AngularJS you can query a lightweight-web-server in your network.
That service then can return IP and/or name of your client based on the connection request made by AngularJS.
Unfortunately, I am not that familiar with AngularJS to be able to program such a service request. So I leave the point open. Perhaps someone can be found who can provide further details on the AngularJS implementation.
