Hi together,
I could need a little help with the following problem: I am using a Homematic USB Stick (HM-CFG-USB-2) and got hmland and homegear working. Everything seems great, the devices are paired with Homegear and all are found and usable in openHAB, which I like very much. That’s the good news.
What I just don’t get is, why is the state in OpenHAB not updated? I mean, if I manually switch something on or off (physically, not in openHAB), this is not shown in OpenHAB. (Also not after waiting for a few minutes, when refreshing the page, re-opening the browser, …) It’ll only be updated after a complete restart of OpenHAB on the server.
I’ve checked the homegear logs: The switch event is correctly registered there and as I interpret it, homegear then connects to openHAB on Port 9126 and sends the corresponding message, which is replied with an answer (please see log below). Strange enough I don’t see anything corresponding in the openHAB logs, even if I set the level to debug. I can’t make head or tail of it.
The same seems to be the case when using e. g. the network binding: If a device goes offline, this is not recognized. (But a haven’t investigated this one in detail yet, so this might be misleading…)
Can you give me any hint?
(Disclaimer: Please forgive me, if this is a n00b or answered-a-thousand-times-already question! I have really been searching a lot before posting here… )
Many thanks in advance!!
08/11/17 21:43:21.364 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "hmland": Debug: Packet received from HM-CFG-LAN: E30C363,0000,0583FE1E,FF,FFC9,3AA41030C363FD2EF406010000
08/11/17 21:43:21.365 Debug (hmland): Packet 0D3AA41030C363FD2EF406010000 enters raisePacketReceived.
08/11/17 21:43:21.365 Debug (hmland): Packet 0D3AA41030C363FD2EF406010000 is now passed to the EventHandler.
08/11/17 21:43:21.365 HomeMatic BidCoS packet received (hmland, RSSI: -55 dBm): 0D3AA41030C363FD2EF406010000
08/11/17 21:43:21.366 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 2 with serial number LEQ1170731 was set to 0x00.
08/11/17 21:43:21.366 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 2 with serial number LEQ1170731 was set to 0x00.
08/11/17 21:43:21.366 RPC client: Debug: Calling RPC method "system.multicall" on server 127.0.0.1.
08/11/17 21:43:21.366 RPC client: Parameters:
(Array length=1)
(Struct length=2)
[methodName]
(String) event
[params]
(Array length=4)
(String) RF-e4d585e4
(String) LEQ1170731:0
(String) RSSI_DEVICE
(Integer) -55
08/11/17 21:43:21.367 Debug: Calling getFileDescriptor...
08/11/17 21:43:21.367 Debug: Connecting to host 127.0.0.1 on port 9126...
08/11/17 21:43:21.368 Debug: Connected to host 127.0.0.1 on port 9126. Client number is: 3834
08/11/17 21:43:21.368 RPC client: Debug: Sending packet: 42696E00000000970000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6534643538356534000000030000000C4C4551313137303733313A30000000030000000B525353495F44455649434500000001FFFFFFC9
08/11/17 21:43:21.372 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
08/11/17 21:43:21.373 RPC client: Debug: Received packet from server 127.0.0.1: 42696E0100000015000001000000000100000003000000056576656E74
08/11/17 21:43:21.373 RPC client: Response was:
(Array length=1)
(String) event
08/11/17 21:43:21.425 RPC client: Debug: Calling RPC method "system.multicall" on server 127.0.0.1.
08/11/17 21:43:21.425 RPC client: Parameters:
08/11/17 21:43:21.425 Debug (hmland): Packet processing of packet 0D3AA41030C363FD2EF406010000 took 60 ms.
(Array length=2)
(Struct length=2)
[methodName]
(String) event
[params]
(Array length=4)
(String) LEQ1170731:1
(String) STATE
(Boolean) 0
(Struct length=2)
[methodName]
(String) event
[params]
(Array length=4)
(String) WORKING
(Boolean) 0
08/11/17 21:43:21.425 Debug: Calling getFileDescriptor...
08/11/17 21:43:21.425 Debug: Connecting to host 127.0.0.1 on port 9126...
08/11/17 21:43:21.426 Debug: Connected to host 127.0.0.1 on port 9126. Client number is: 3835
08/11/17 21:43:21.427 RPC client: Debug: Sending packet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
08/11/17 21:43:21.429 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
08/11/17 21:43:21.430 RPC client: Debug: Received packet from server 127.0.0.1: 42696E0100000015000001000000000100000003000000056576656E74
08/11/17 21:43:21.431 RPC client: Response was:
(Array length=1)
(String) event
08/11/17 21:43:24.738 RPC Server (Port 39487): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
08/11/17 21:43:24.739 RPC Server (Port 39487): Info: Client number 3823 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/11/17 21:43:24.739 RPC Server (Port 39487): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC3139065
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
(String) Homegear default BidCoS interface
08/11/17 21:43:24.739 RPC Server (Port 39487): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433331333930363500000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
