I recently upgraded from OH 2.3 -> 2.4. I ran into some small issues and solved most.
One thing I noticed is that I started getting lines like the following in my log:
2019-05-09 07:19:49.856 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '3.0' with the file 'dehumid.map' : Target value not found in map for '3.0'
I have a state machine that monitors my dehumidifier’s current and transofrms that into a state.
It is declared in my .items file like this:
Number dehumidState "Dehumidifier [MAP(dehumid.map):%s]" <humidity>
dehumid.State then is set to a number 0-3 dependant on the current level in a rule
Then I transform that number into a human readable state in the following map file:
0=Off
1=On/Idle
2=On/Running
3=Auto/Off
NULL=Unknown
null=Unknown
-=Unknown
It looks like a number item now contains 1 decimal where in OH 2.3 it was 0 decimals? I fixed this by modifying my .map file to add a “.0” to each state. Just curious should I instead be using a different item type than number?
