Hello Rich,
I have a JAR file saved here if you want to test it. Let me know what you think. Thanks.
Hello Rich,
I manually set up my DSC Partition/Zones using a dscalarm.things file but itās still doing the discovery and CPU utilization is still pretty high.
https://www.evernote.com/l/AAvXSbvDT6hFdJ_5ZE8QNf1w6GYeo_yG9SIB/image.png
Iāll test it through the day and see if the CPU goes down at all.
Hello Rich,
I basically concentrated on getting the the binding connected to the IT100 which became a priority. I did put in a 30 second delay for the bridge background discovery scheduler. What you are seeing in the logs isnāt the bridge discovery, but the device discovery. As the binding receives messages from the panel it determines if the device is one of itās own things, or needs to be added to the discovery inbox. That canāt be changed. I have put a version out that turns off background discovery here, if you want to test that. Of course the only way to do a bridge discovery will be through the PaperUI now, which may not be a bad idea.
Thanks for the additional info.
CPU usage has stabilized down to about 3% so Iāll let it run through the day with the jar you sent me yesterday!
Would it be possible to add a setting that we can use to disable discovery, sortof like commenting it out?
I wound up going back to OpenHab 1.8.2 because I had High CPU utilization with most of the OH2 builds when using the DSCAlarm Binding. Iām not even sure if this is related to Discovery or not (but that was my hunch)
The one OH2 build that didnāt have high CPU issues wasnāt firing off rules
I occasionally download a new OH2 build and test but think this issue needs to get fixed first: Error āScript interpreter couldnāt be obtainā #191
@RichP you using it with an it100 or envisalink?
I currently use it with the it100 and donāt have high cpu usage. I do have a scheduled rule that triggers a status update, but even with that my cpu load is 0.00 on a KVM VPM, which has 2 cores and 512MB ram only.
I just moved OpenHab 1.8.2 to a RPi 3 and so far itās running really well.
I will try to get OH2 running on it the RPi as well and see the high cpu reappearsā¦maybe itās related to running OH2 on a mac.
Installed the latest OH2 Snapshot Build #293 on my iMac (quad core)
Shortly after enabling the DSCAlarm binding from within PaperUI, CPU usage for Java goes from about .4% to 300%+
Iāll let this run for a few hours and see if it stabilizes.
Either way, Iāll figure out how to move this install to my Raspberry Pi 3 and see if it behaves the same.
https://www.evernote.com/l/AAuLOIW2UedFB4fuXCKYGdVjEto-F8qZKpMB/image.png
Good news! Moved OH2 to the RPi3 and I do NOT see the same high CPU usage with the DSCAlarm binding!
Must be related to something specific on OSX.
This screenshot is after OH2 has been running for about 18 hours.
https://www.evernote.com/l/AAvoFNCKlOhCO4WRTaA_7b97OFmV9aS6Sz8B/image.png
Good to hear. I tried to duplicate your issue on my Windows based OH server but couldnāt. As you say, it must be an OSX problem. Glad it is working.
Yeah, I am pretty happy and itās been rock solid for a few days now with the same low CPU utilization.
I originally got the RPi3 for a robot project but I guess I will be āforcedā to purchase another one now
