Short summary:
An item A on Thing T (that is definied within an items file) was not receiving updates. Then I defined a second item B on thing T using Paper-UI or Habmin (I tried both) with the result that A is getting updates. When I delete item B, item A is not getting updates anymore. This behaviour is reproducable! For details: read on.
Since the topic changed a bit, I decided to create a new topic instead of adding this new information to the other thread so that other community members who have the same problem become aware of this thread.
- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: openHABian / Raspbian GNU/Linux 8 (jessie)
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: 2.5.0~S1479-1 (Build #1479)
- binding-zwave: 2.5.0.SNAPSHOT
Detailed description:
As stated in my last posted topic ([SOLVED] Some Z-Wave battery devices are not updating battery level) I had a problem with items that were not being updated. While I tried to get to the bottom of the problem with the support of the community members @chris, @HomeAutomation and @mstormi (see that thread), I recognized that a part of the solution was found by adding a new item by using Paper-UI or Habmin beside the existent ones I defined within an items file (see my last comment in that thread: [SOLVED] Some Z-Wave battery devices are not updating battery level). The strange thing is that the item that was defined within the items file is then getting updates - as long as the new item (created within the UI) is existent. As soon as I delete that new item, the old one is not getting updates anymore. So it looks as if the new item makes the old one working as long as it exists.
My configuration:
items file:
Number klingelsensor_batterylevel "Klingelsensor/Batterie [%s %%]" <battery> { channel="zwave:device:71a23be9:node14:battery-level" }
Contact doorbell "Klingel betätigt" <contact> { channel="zwave:device:71a23be9:node14:sensor_door" }
DateTime klingelsensor_batterylevel_update "Klingelsensor-Batterie / Letzte Akt.: [%1$td.%1$tm.%1$tY, %1$tH:%1$tM Uhr]" <time>
rules file:
rule "Klingelsensor Battery-Level updated"
when Item klingelsensor_batterylevel received update
val lastUpdate = klingelsensor_batterylevel_update.state
klingelsensor_batterylevel_update.postUpdate( new DateTimeType() )
logInfo("Rules", "Klingelsensor last update timestamp updated. Previous value: " + lastUpdate.toString )
Here’s my test:
As long as the “UI”-item exists, the items-file item works fine as you can see from the rules log file:
2019-01-15 11:44:54.210 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-15T00:00:28.408+0100
2019-01-15 17:36:52.102 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-15T11:44:54.200+0100
2019-01-15 23:28:56.693 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-15T17:36:52.093+0100
2019-01-16 11:15:06.337 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-15T23:28:56.684+0100
Then I deleted the item that I created within the UI on 2019-01-16 14:09:51.853. From then on, no updates are received (no entries and no exceptions in the log file!)
On 2019-01-19 I created a new item beside the existent one again by using the UI.
2019-01-19 09:58:56.877 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-16T11:15:06.325+0100
2019-01-19 15:50:45.229 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-19T09:58:56.858+0100
2019-01-19 21:45:54.094 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-19T15:50:45.211+0100
2019-01-20 03:38:16.427 [INFO ] [eclipse.smarthome.model.script.Rules] - Klingelsensor last update timestamp updated. Previous value: 2019-01-19T21:45:54.079+0100
As you can see, the updates are incoming again. With the first update you can see that nothing happened between since it’s referencing the last action on the 16th of January.
During that test, I did not change anything else within the configuration! And there were no exceptions in the logfile!
I wouldn’t put my hand on the fire for that, but I don’t think I’ve configured anything wrong here. Instead, I’m assuming a bug.
Are there other users who have recognized a similar behaviour? Should I file a bug for this or did I make something wrong?
Thank you in advance for your support!
