Hey guys,
I just flashed my Sonoff S20 sockets with the newest Tasmota Firmware.
Now I saw a strange behaviour. When I switch the Socket from the Tasmota Web Interface it sends out the following and installed command:
19:23:38 MQT: tasmota/sonoff-******/stat/RESULT = {"POWER":"ON"}
19:23:38 MQT: tasmota/sonoff-******/stat/POWER = ON
If I send the command via the following item it sends the following command:
Switch Max_Sonoff_S20_****** "Stehlampe" <light> (Lights_MaxZimmer, Lights) {mqtt=">[broker:tasmota/sonoff-******/cmnd/POWER:command:*:default], <[broker:tasmota/sonoff-******/stat/POWER:state:default]"}
Tasmota-Log:
19:24:38 MQT: stat/sonoff-******/RESULT = {"POWER":"ON"}
19:24:38 MQT: stat/sonoff-******/POWER = ON
So why are there those different commands. The problem is, that when I switch the socket via Alexa, the normal item is not updated, cause it waits for the tasmota/sonoff-******/stat command and not the stat/sonoff-****** command.
Thank you guys!!
