I mananged to get a running installation openHAB 2.1 with digitalstrom Binding on an RPI using the PaperUI.
Now all GE-Device (gelb) in THING are somehow not working. I do the same with a Szene/Stimmung and it working proberly in the HABPanel. I have version 1.42.10 of DigitalServer.
I’m new in this domain and I’m asking me what I do wrong.
Can somebody please help?
It would be great, if you could describe your issues a bit more detailed.
What exactly is not working ?
I am using digitalSTROM here as well and can confirm that it is running rock solid with GE, GR and SW devices.
I configured the think in Paper UI and add a switch widget in HABPanel selecting the new add think.
Then I try to switch and nothing happens. I did the same with Szene it is working fine like you said.
I hope it little bit better described. Thank you in advance for your help.
Thanks, but this is not what I asked for.
To control your device, you need to define an item in your .items file under conf/items.
This is what I wanted to see.
I guess you don’t understand me, I am asking for manual item vonfiguration through as .items config file, not manually created with PaperUI.
something like this
now I can see the status of light in all panels when i press the wall-switch, BUT is not working on the Classic / Basic / HABPanel when I press the virtual-switch
