controlc
(controlc)
February 19, 2018, 10:33am
#1
In the original Philips Hue Motion Sensor rules
a light will be set on if Motion Sensor detect something.
After then a timer will be started (I think 3 minutes).
And 30 seconds before timer will be of a command will be dim the lights.
if timer stop light will be set off
if timer is running an motion will detect the timer is restarting
I have a rule, that covered point 1 and 2 (and 4 and 5) but I have no clue how to solve point 3.
Here is my current rule
rule "Rule 3"
Item BewegungsmelderFlur_1 changed from OFF to ON
logInfo("rule_3", "Start")
Thread::sleep(100) // give persistence time to save the update
var hour = now.getHourOfDay
val int timeoutMinutes = 3
if (timers3 === null){
if ( hour < 7 || hour >= 22 ) {
logInfo("rule_3", "Nachtschaltung")
sendCommand(gLightTestDimmer, 10) }
if ( hour < 22 && hour >= 20 ) {
logInfo("rule_3", "Abendschaltung")
sendCommand(gLightTestDimmer, 30) }
if ( hour < 20 && hour >= 7 ) {
logInfo("rule_3", "Tagesschaltung")
sendCommand(gLightTestDimmer, 100) }
timers3 = createTimer(now.plusMinutes(timeoutMinutes), [|
sendCommand(gLightTestSwitch, OFF)
timers3 = null ])
else {
logInfo("rule_3", "Timer wird zurueckgesetzt ...")
timers3.reschedule(now.plusMinutes(timeoutMinutes))
controlc
(controlc)
February 19, 2018, 1:58pm
#2
The question is: How could I get time remaining from the Timer? And is it possible to add the dim function into this rule or should it an additional rule?
Hello
Why you dont split it into 2 timers?
Instead of Timeout 3 minutes - 30 seconds.
Timer 1 2min 30s, Timer 2 30s
controlc
(controlc)
February 19, 2018, 2:59pm
#4
Do you mean like that?
var Timer timer3 = null
var Timer dim3 = null
rule "Rule 3"
val int dimSeconds = 30
//Switch Light On
//Start timer
dim3 = createTimer(now.PlusSeconds(dimSeconds), [|
timers3 = null ])
dim3 = null ])
else {
dim3 = null
Maybe this could work - but isn“t it to complicated to restart the timer? I don“t know if it works if the dim3 Timer is started.
Hello Controlc
Yes, this should it be nearly.
should be
if ((timers3 === null) && (dim3 == null)){
dim3 = null ])
timers3 = null ])
and
else if ((timers3 != null) && (dim3 == null)) {
dim3.cancel
dim3 = null
else if (dim3 != null) {
dim3.cancel
dim3 = null
dim3 = null ])
timers3 = null ])
This code is written out of the head, with no validation.
The idea is to check wich dimmer is running (because if dim3 is running, the light is already dimmed)
BTW with your setting you have now 3 min + 30 s.
If oyu change timer3 to 90 seconds you archive the 3 minutes goal.
regards
Michael
controlc
(controlc)
February 19, 2018, 4:02pm
#6
Hi Michael,
I“ve used your code (with some simple corrects) and now thats the complete rule:
var Timer timers3 = null
rule "Rule 3"
Thread::sleep(100)
val int timeoutSeconds = 90
val int dim3Seconds = 30
logInfo("rule_3", "Motion rule: Wir haben die Stunde " +hour)
if ((timers3 === null) && (dim3 === null)){
// Nachtschaltung
// Abendschaltung
// Tagschaltung
timers3 = createTimer(now.plusSeconds(timeoutSeconds), [|
dim3 = createTimer(now.plusSeconds(dim3Seconds), [|
dim3 = null ])
timers3 = null ])
else if ((timers3 !== null) && (dim3 === null)) {
logInfo("rule_3", "Dimm-Stufe noch nicht erreicht. Timer wird zurueckgesetzt ...")
timers3.reschedule(now.plusSeconds(timeoutSeconds))
else if (dim3 !== null) {
logInfo("rule_3", "Timer bereits in Dimm-Stufe. Timer wird zurueckgesetzt ...")
dim3.cancel
(dim3 = null)
// Nachtschaltung
// Abendschaltung
// Tagschaltung
dim3 = createTimer(now.PlusSeconds(dim3Seconds), [|
dim3 = null ])
timers3 = null ])
logInfo("rule_3", "End")
So itĀ“s working but I have to say āSchƶn ist was anderes!ā - My hope was a more shorter code but hey: It works!
Thanks a lot! But if someone else got a better solution I“m already interested .
controlc:
You are so right ^^ But the code is, was nobody seeās. Only the result.
I would be happy to learn a easier way.
BR
Michael
