i am planning a new Home an want to get dimmable LED-Spots for a few Rooms.
When finished, the following should be possible:
4 to 10 LED Spots (in the ceilling) per Room should be controllable via OpenHAB2 in each Room.
For each Room i need a/multiple piece(s) of Hardware that can do the following jobs:
- a LED Driver, that can support 10x8W (80Watt) that support PWM signal for dimming.
- A Controller/Board that can run Tasmota Firmware for using mqtt and generating PWM Signal.
in each Room, all LEDs should be dimmed equaly (LEDs connectected all to the same power-lane)
My Problem:
i have read multiple times, that PWM Signals are software based on most cheap Controllers, which may result in flickering.
I am not sure if there are Devices available which can exactly do what i want. Wihtout need of seperate controller an LED-Driver.
If you have any hints wich hardware i should use, please let me know.
I want to control only white LED Spots, no RGB.
Thank
kind regards
