As mentioned in another post I am trying to switch over to OH 2.0 and I’m running into a few small issues. What I’m looking at now is I have 2 lights in a ceiling fan. They are Philips Hue regular white bulbs. Now each bulbs is showing as a thing. I’ve created 2 items for each thing. A Switch and a Dimmer, however I think I read last night that you don’t need both and can just use a dimmer item? Am I correct in stating that? So for each bulb in the thing, I linked them to the proper items. However, the switch worked and the dimmer did not.
Also I know in 1.8 in order to get my lights to work together I had to set up a dummy switch/dimmer and had to run a rule. When I was looking at the thing I see you can link to multiple switches/dimmers. I tried to link both lights to the same switch and another dimmer and this did not work. I got no response from the lights. Is this not how it is to work? If not, how do you setup multiple lights to 1 switch and or dimmer.
