I get an exception in the log on my dimmers that are defined as follows:
Excerpt from my rfxcom.things file
Thing lighting2 62655742_5 [deviceId="62655742.5", subType="AC"]
From my lights.items file
Dimmer Living_Room_Window { channel="rfxcom:lighting2:rfxtrx433:62655742_5:dimminglevel" }
Defined in the sitemap as
Slider item=Living_Room_Window
The exception in the logs
19:14:03.902 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Living_Room_Window' received command 47
19:14:03.910 [INFO ] [marthome.event.ItemStateChangedEvent] - Living_Room_Window changed from NULL to 47
19:14:04.093 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while calling handler: java.lang.IllegalArgumentException: Not valid value selector
java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException: Not valid value selector
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_111]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_111]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.thing.internal.ThingManager.receiveCommand(ThingManager.java:364)[103:org.eclipse.smarthome.core.thing:0.9.0.201612091054]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:46)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[96:org.eclipse.smarthome.core:0.9.0.201612091054]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_111]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Caused by: java.lang.IllegalArgumentException: Not valid value selector
at org.openhab.binding.rfxcom.RFXComValueSelector.getValueSelector(RFXComValueSelector.java:120)[173:org.openhab.binding.rfxcom:2.0.0.201612091712]
at org.openhab.binding.rfxcom.handler.RFXComHandler.handleCommand(RFXComHandler.java:82)[173:org.openhab.binding.rfxcom:2.0.0.201612091712]
at org.eclipse.smarthome.core.thing.internal.ThingManager$3.call(ThingManager.java:367)[103:org.eclipse.smarthome.core.thing:0.9.0.201612091054]
at org.eclipse.smarthome.core.thing.internal.ThingManager$3.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201612091054]
... 5 more
19:14:04.096 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Living_Room_Window' received command 47
