I don’t have old ones in the http.cfg. - that’s the strange part.
Anyway -thanks for your detailed step by step guide.
I will try is right away.
The old values are deleted in the karaf console.
I still can see them in Paper UI…
Even after a http binding restart i get tons of:
2019-08-22 20:26:42.879 [DEBUG] [ab.binding.http.internal.HttpBinding] - item 'DWD_Birke_2' is not a valid URL or is a cache id yet to be initialised (cachePollen)
Are you sure you deleted all old configuration?
Have you looked to see what is in http.config ? Have you deleted it (after stopping OH) ?
I think the bit that messes up is when you remove things from http.cfg. “the process” is too dim witted to remove from http.config
Thanks guys for your patience.
That’s what I am going to try:
I might have forgotten the “update” part of your guide…
Copying back the http.cfg did solve the error messages above
Thank you guys so much!
