I just got a dimmer and in the ipad it renders to a slider and in the browser it renders to Increase and Decrease button.
I saw in another topic that it is not possible to render in the ipad as a slider. Is this correct?
In the browser, the increase and decrease buttons are not working in any way. How can I fix this? In the event log I can see and INCREASE and DECREASE event, but the value for the element doesn’t change.
I have to say also that the dimmer up/down buttons in my browser pretty much don’t work as well. I thought this was something to do with my specific setup / combination, or perhaps only an issue in Chrome browser?
I am using android app and dimmer sliders are rendered / work properly. Trouble is they don’t work in the browser (they render as UP/DOWN buttons). My understanding is if you want them to work by pressing up down buttons you have to use the rule from the demo example :
This is a demo rule which simulates a real dimmer by reacting to increase/decrease commands
and posting an updated state on the bus
rule “Dimmed Light”
Item DimmedLight received command
var Number percent = 0
if(DimmedLight.state instanceof DecimalType) percent = DimmedLight.state as DecimalType
Just for a reference in case sb was wondering, those are some working/tested rules as the demo ones do not work for me in classic UI:
rule "Implement INCREASE and DECREASE commands for a zwave dimmer"
Item WallLamps received command INCREASE or
Item WallLamps received command DECREASE
logInfo("walllamps.rules", "triggered")
if(WallLamps.state != Uninitialized)
percent = WallLamps.state
