In basic UI, I tried Switch, it is working perfectly fine. But when I add Dimmer or other types, it stopped working. Below are my codes. I’m using Openhab 2.1.0 on my windows laptop btw.
In items file:
Switch Wallplug_TV_Jessie "Wallplug TV" <poweroutlet> { channel="samsungtv:tv:6cd29ac0_aaee_451c_a85e_5c41b771c67a:power" }
Switch Mute_TV_Jessie "Mute TV" <switch> { channel="samsungtv:tv:6cd29ac0_aaee_451c_a85e_5c41b771c67a:mute" }
Dimmer Volume_TV_Jessie "Volume of TV" <soundvolume> { channel="samsungtv:tv:6cd29ac0_aaee_451c_a85e_5c41b771c67a:volume" }
Number Channel_Number_TV_Jessie "Channel number of TV" <number> { channel="samsungtv:tv:6cd29ac0_aaee_451c_a85e_5c41b771c67a:channel" }
In sitemap file:
Switch item=Wallplug_TV_Jessie label="Jessie's smart TV"
Switch item=Mute_TV_Jessie label="Mute my TV"
Dimmer item=Volume_TV_Jessie label="Volume of TV"
Number item=Channel_Number_TV_Jessie label="Channel number"
when I open http://localhost:8080/basicui/app
It keeps giving me this error:
It seems like you have not defined any sitemaps yet. To build one, please check the documentation for guidance.
In my openhab logs file, it says:
2017-10-23 03:55:37.391 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘default.sitemap’ has errors, therefore ignoring it: [6,5]: mismatched input ‘Dimmer’ expecting ‘}’
If I remove the two lines of dimmer and number in my sitemap file, it works fine, as in the picture below.
Is it because of the item type? Did I make any mistakes? I’ve been looking at these for a couple hours and couldn’t figure out. If someone knows, please help me. Thanks!!!
