Hey,
I am quite new to OpenHab and to KNX also… so sorry if my questions are too low level
My OpenHab 2 is installed and seems to work.
Switching lights does work.
But as soon, as i want to dimm that light, it does not work.
My setup for that example light:
// switch = 2/0/40
// dimm = 2/1/40
// value = 2/2/40
// state = 2/3/40
// rm_value = 2/4/40
// lock = 2/5/40
// reserved = 2/6/40
Dimmer Testlight “testlight [%d %%]” (EG_Wohnzimmer) { knx=“2/0/40+<2/3/40, 2/6/40, 2/1/40+<2/4/40” }
In the HABpanel the slider gets the switch-value of the lamp, so if i turn it on somewhere else, it moves from 0 to 100.
Changing the value looks inside the events.log like:
2017-06-05 19:27:54.725 [ItemStateChangedEvent ] - Testlight changed from 100 to 0
2017-06-05 19:27:58.507 [ItemCommandEvent ] - Item ‘Testlight’ received command 100
2017-06-05 19:28:16.700 [ItemCommandEvent ] - Item ‘Testlight’ received command 100
2017-06-05 19:28:19.601 [ItemCommandEvent ] - Item ‘Testlight’ received command 20
2017-06-05 19:28:19.850 [ItemCommandEvent ] - Item ‘Testlight’ received command 20
2017-06-05 19:28:21.557 [ItemCommandEvent ] - Item ‘Testlight’ received command 100
But… it does not change the light.
Anyone able to help me a little bit to the next level?
Patrick
p. s. Do you have any good getting-started link to me? I understood the files and meanings of them, but as soon as it comes to knx i dont see any good documentation anywhere.
