I have the HTTP Binding working with DirecTV and Alexa and I want to share my work. The scope of this work includes one DirecTV Genie and one or more Mini Genies. JSON parsing is not included since I only want to send voice commands to Alexa and control my set-top boxes. I modeled this solution from @TrevorG’s recent post, but I will provide some details that I have not found elsewhere in OpenHAB topics.
The first step is to port forward the internal IP address for the DirecTV Genie to 8080. The Mini Genie communicates through the same IP address, so its only necessary to port forward the DirecTV Genie. The IP address of the DirecTV Genie is found at: Menu -> Settings -> Internet Setup -> Advanced Setup. Port forward the Server IP address to 8080. It is best to set this as static ip address on your router.
Before leaving the DirecTV Genie Settings, go to Menu -> Settings -> Whole-Home -> External Devices. Make sure that “External Access” is set to “Allow”. Also, Menu -> Settings -> Whole-Home -> Manage Clients -> Network Details. Copy the MAC Address(es) of the client(s) i.e. Mini Genies. MAC address of each Mini Genie will be used in the HTTP Binding protocol to send commands.
I use two different HTTP syntax commands for DirecTV Genie:
1.) The Remote Keys Request Commands. Remote Keys Commands mimics a button press on DirecTV remote controls. An example for the “Menu Button” command is:
http=">[*:GET:http://IPaddress:port/remote/processKey?key=menu&hold=keyPress:default]"
Where you would replace IPaddress:port with the ip address identified earlier, such as:
http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=menu&hold=keyPress:default]"
2.) The second type of command is the Tune Request Command which I use for favorite channels. An example of a tune request for channel 9 is:
http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=009]
Mini Genie Commands:
Since Mini Genies do not have their own IP address, the http bining communicates with Mini Genies by appending their MAC address to DirecTV Genie commands. For example, if the MAC address of a Genie is:99F7C76B68BE, the “Menu Button” command is:
http=">[*:GET:http://192.168.1.210:8080/remote/processKey?key=menu&hold=keyPress&clientAddr=99F7C76B68BE:default]"
The Mini Genie request for channel 9 is:
http=">[*:GET:http://192.168.1.210:8080/tv/tune?major=009&clientAddr=99F7C76B68BE]"
My http.cfg file is
GenieCache.url=http://192.168.1.210:8080/tv/getTuned
GenieCache.updateInterval=50000
To control http functions with Alexa, I turned them into lights. To make it easy for me to distiguish between my set-top boxes, I refer to the Genie as “TV” and I refer to the Mini Genie as “Cable”. My items file is as follows:
Switch HDDVR_GUIDE "TV Guide" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=guide&hold=keyPress:default]" }
Switch HDDVR_RED "TV Delete" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=red&hold=keyPress:default]" }
Switch HDDVR_EXIT "TV Exit" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=exit&hold=keyPress:default]" }
Switch HDDVR_PREV "TV Last Channel" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=prev&hold=keyPress:default]" }
Switch HDDVR_MENU "TV Menu" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=menu&hold=keyPress:default]" }
Switch HDDVR_LIST "TV List" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=list&hold=keyPress:default]" }
Switch HDDVR_RECORD "TV Record" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=record&hold=keyPress:default]" }
Switch HDDVR_BACK "TV Back" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=back&hold=keyPress:default]" }
Switch HDDVR_INFO "TV INFO" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=info&hold=keyPress:default]" }
Switch HDDVR_SELECT "TV SELECT" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=select&hold=keyPress:default]" }
Switch HDDVR_UP "TV UP" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=up&hold=keyPress:default]" }
Switch HDDVR_DOWN "TV DOWN" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=down&hold=keyPress:default]" }
Switch HDDVR_ENTER "TV ENTER" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=enter&hold=keyPress:default]" }
Switch HDDVR_PAUSE "TV PAUSE" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=pause&hold=keyPress:default]" }
Switch HDDVR_PLAY "TV PLAY" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=play&hold=keyPress:default]" }
Switch HDDVR_CNN "TV CNN" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=202]" }
Switch HDDVR_MSNBC "TV MSNBC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=356]" }
Switch HDDVR_NBC "TV NBC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=004]" }
Switch HDDVR_ABC "TV ABC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=007]" }
Switch HDDVR_CBS "TV CBS" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=009]" }
Switch HDDVR_SPIKE "TV SPIKE" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=241]" }
Switch HDDVR_USA "TV USA" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=242]" }
Switch HDDVR_SCI_FI "TV SCI FI" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=244]" }
Switch HDDVR_TNT "TV TNT" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=245]" }
Switch HDDVR_FX "TV FX" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=248]" }
Switch HDDVR_COMEDY "TV COMEDY" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=249]" }
Switch HDDVR_AMC "TV AMC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=254]" }
Switch HDDVR_HGTV "TV HGTV" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=229]" }
Switch HDDVR_ION "TV ION" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=305]" }
Switch HDDVR_FOOD "TV FOOD NETWORK" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=231]" }
Switch GENIE_MINI_GUIDE "Cable Guide" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=guide&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_RED "Cable Delete" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=red&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_EXIT "Cable Exit" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=exit&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_PREV "Cable Last Channel" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=prev&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_MENU "Cable Menu" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=menu&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_LIST "Cable List" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=list&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_RECORD "Cable Record" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=record&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_BACK "Cable Back" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=back&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_INFO "Cable Info" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=info&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_SELECT "Cable SELECT" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=select&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_UP "Cable UP" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=up&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_DOWN "Cable DOWN" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=down&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_ENTER "Cable ENTER" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=enter&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_PAUSE "Cable PAUSE" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=pause&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_PLAY "Cable PLAY" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/remote/processKey?key=playr&hold=keyPress&clientAddr=99F7C76B68BE:default]" }
Switch GENIE_MINI_CNN "Cable CNN" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=202&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_MSNBC "Cable MSNBC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=356&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_NBC "Cable NBC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=004&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_ABC "Cable ABC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=007&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_CBS "Cable CBS" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=009&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_SPIKE "Cable SPIKE" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=241&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_USA "Cable USA" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=242&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_SCI_FI "Cable SCI FI" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=244&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_TNT "Cable TNT" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=245&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_FX "Cable FX" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=248&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_COMEDY "Cable COMEDY" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=249&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_AMC "Cable AMC" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=254&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_HGTV "Cable HGTV" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=229&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_ION "Cable ION" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=305&clientAddr=99F7C76B68BE]" }
Switch GENIE_MINI_FOOD "Cable FOOD NETWORK" <light> ["Lighting"] { http=">[*:GET:http://192.168.1.10:8080/tv/tune?major=231&clientAddr=99F7C76B68BE]" }
My Sitemap is:
Frame label="DirecTV Genie - AKA - TV"{
Switch item=HDDVR_GUIDE label="TV Guide"
Switch item=HDDVR_RED label="TV Delete"
Switch item=HDDVR_EXIT label="TV Exit"
Switch item=HDDVR_PREV label="TV Last Channel"
Switch item=HDDVR_EXIT label="TV Menu"
Switch item=HDDVR_RECORD label="TV Record"
Switch item=HDDVR_BACK label="TV Back"
Switch item=HDDVR_INFO label="TV Info"
Switch item=HDDVR_SELECT label="TV SELECT"
Switch item=HDDVR_UP label="TV UP"
Switch item=HDDVR_DOWN label="TV DOWN"
Switch item=HDDVR_ENTER label="TV ENTER"
Switch item=HDDVR_PAUSE label="TV PAUSE"
Switch item=HDDVR_PLAY label="TV PLAY"
Switch item=HDDVR_CNN label="TV CNN"
Switch item=HDDVR_MSNBC label="TV MSNBC"
Switch item=HDDVR_NBC label="TV NBC"
Switch item=HDDVR_ABC label="TV ABC"
Switch item=HDDVR_CBS label="TV CBS"
Switch item=HDDVR_SPIKE label="TV SPIKE"
Switch item=HDDVR_SCI_FI label="TV SCI FI"
Switch item=HDDVR_TNT label="TV TNT"
Switch item=HDDVR_FX label="TV FX"
Switch item=HDDVR_COMEDY label="TV COMEDY"
Switch item=HDDVR_AMC label="TV AMC"
Switch item=HDDVR_HGTV label="TV HGTV"
Switch item=HDDVR_ION label="TV ION"
Switch item=HDDVR_FOOD label="TV FOOD NETWORK"
Frame label="Genie Mini - AKA - Cable"{
Switch item=GENIE_MINI_GUIDE label="Cable Guide"
Switch item=GENIE_MINI_RED label="Cable Delete"
Switch item=GENIE_MINI_EXIT label="Cable Exit"
Switch item=GENIE_MINI_PREV label="Cable Last Channel"
Switch item=GENIE_MINI_MENU label="Cable Menu"
Switch item=GENIE_MINI_LIST label="Cable List"
Switch item=GENIE_MINI_RECORD label="Cable Record"
Switch item=GENIE_MINI_BACK label="Cable Back"
Switch item=GENIE_MINI_INFO label="Cable Info"
Switch item=GENIE_MINI_SELECT label="Cable SELECT"
Switch item=GENIE_MINI_UP label="Cable UP"
Switch item=GENIE_MINI_DOWN label="Cable DOWN"
Switch item=GENIE_MINI_ENTER label="Cable ENTER"
Switch item=GENIE_MINI_PAUSE label="Cable PAUSE"
Switch item=GENIE_MINI_PLAY label="Cable PLAY"
Switch item=GENIE_MINI_CNN label="Cable CNN"
Switch item=GENIE_MINI_MSNBC label="Cable MSNBC"
Switch item=GENIE_MINI_NBC label="Cable NBC"
Switch item=GENIE_MINI_ABC label="Cable ABC"
Switch item=GENIE_MINI_CBS label="Cable CBS"
Switch item=GENIE_MINI_SPIKE label="Cable SPIKE"
Switch item=GENIE_MINI_USA label="Cable USA"
Switch item=GENIE_MINI_SCI_FI label="Cable SCI FI"
Switch item=GENIE_MINI_TNT label="Cable TNT"
Switch item=GENIE_MINI_FX label="Cable FX"
Switch item=GENIE_MINI_COMEDY label="Cable COMEDY"
Switch item=GENIE_MINI_AMC label="Cable AMC"
Switch item=GENIE_MINI_HGTV label="Cable HGTV"
Switch item=GENIE_MINI_ION label="Cable ION"
Switch item=GENIE_MINI_FOOD label="Cable FOOD NETWORK"
These items are discoverable by Alexa and voice commands work well.
Finally, I found that navigating the DirecTV Menu or List pages was tedious with a single up or down command. I would have to say, “Alexa, Turn On TV UP”, multiple times. So, I’m experiementing with rules that repeat commands. This isn’t pretty, so I’m open to more elegant solutions. I added the following to my Items file:
Switch Switch_forRule_2x_TV_Up_Command "2 TV UP" <light> ["Lighting"]
Switch Switch_forRule_3x_TV_Up_Command "3 TV UP" <light> ["Lighting"]
Switch Switch_forRule_4x_TV_Up_Command "4 TV UP" <light> ["Lighting"]
Switch Switch_forRule_5x_TV_Up_Command "5 TV UP" <light> ["Lighting"]
Switch Switch_forRule_2x_TV_DOWN_Command "2 TV DOWN" <light> ["Lighting"]
Switch Switch_forRule_3x_TV_DOWN_Command "3 TV DOWN" <light> ["Lighting"]
Switch Switch_forRule_4x_TV_DOWN_Command "4 TV DOWN" <light> ["Lighting"]
Switch Switch_forRule_5x_TV_DOWN_Command "5 TV DOWN" <light> ["Lighting"]
Switch Switch_forRule_2x_Cable_Up_Command "2 Cable UP" <light> ["Lighting"]
Switch Switch_forRule_3x_Cable_Up_Command "3 Cable UP" <light> ["Lighting"]
Switch Switch_forRule_4x_Cable_Up_Command "4 Cable UP" <light> ["Lighting"]
Switch Switch_forRule_5x_Cable_Up_Command "5 Cable UP" <light> ["Lighting"]
Switch Switch_forRule_2x_Cable_DOWN_Command "2 Cable DOWN" <light> ["Lighting"]
Switch Switch_forRule_3x_Cable_DOWN_Command "3 Cable DOWN" <light> ["Lighting"]
Switch Switch_forRule_4x_Cable_DOWN_Command "4 Cable DOWN" <light> ["Lighting"]
Switch Switch_forRule_5x_Cable_DOWN_Command "5 Cable DOWN" <light> ["Lighting"]
Then, the corresponding Sitemap additions are:
Switch item=Switch_forRule_2x_TV_Up_Command label="2 TV UP"
Switch item=Switch_forRule_3x_TV_Up_Command label="3 TV UP"
Switch item=Switch_forRule_4x_TV_Up_Command label="4 TV UP"
Switch item=Switch_forRule_5x_TV_Up_Command label="5 TV UP"
Switch item=Switch_forRule_2x_TV_DOWN_Command label="2 TV DOWN"
Switch item=Switch_forRule_3x_TV_DOWN_Command label="3 TV DOWN"
Switch item=Switch_forRule_4x_TV_DOWN_Command label="4 TV DOWN"
Switch item=Switch_forRule_5x_TV_DOWN_Command label="5 TV DOWN"
Switch item=Switch_forRule_2x_Cable_Up_Command label="2 Cable UP"
Switch item=Switch_forRule_3x_Cable_Up_Command label="3 Cable UP"
Switch item=Switch_forRule_4x_Cable_Up_Command label="4 Cable UP"
Switch item=Switch_forRule_5x_Cable_Up_Command label="5 Cable UP"
Switch item=Switch_forRule_2x_Cable_DOWN_Command label="2 Cable DOWN"
Switch item=Switch_forRule_3x_Cable_DOWN_Command label="3 Cable DOWN"
Switch item=Switch_forRule_4x_Cable_DOWN_Command label="4 Cable DOWN"
Switch item=Switch_forRule_5x_Cable_DOWN_Command label="5 Cable DOWN"
Now, for example, if I’m on the List page and I want to select a recorded program that is fifth from the top, I can say, “Alexa Turn On 5 TV Down”. DirecTV will highlight the fifth program and then I can say “Alexa Turn On TV Select”. Then DirecTV will play the recorded program.I added rules to move up or down between 1 and 5 steps. My rules file is shown below.
rule "2x_TV_Up"
Item Switch_forRule_2x_TV_Up_Command received command
if(receivedCommand == ON) {
HDDVR_UP.sendCommand(ON)
rule "3x_TV_Up"
Item Switch_forRule_3x_TV_Up_Command received command
rule "4x_TV_Up"
Item Switch_forRule_4x_TV_Up_Command received command
rule "5x_TV_Up"
Item Switch_forRule_5x_TV_Up_Command received command
rule "2x_TV_DOWN"
Item Switch_forRule_2x_TV_DOWN_Command received command
HDDVR_DOWN.sendCommand(ON)
rule "3x_TV_Up"
Item Switch_forRule_3x_TV_DOWN_Command received command
rule "4x_TV_DOWN"
Item Switch_forRule_4x_TV_DOWN_Command received command
rule "5x_TV_Down"
Item Switch_forRule_5x_TV_DOWN_Command received command
rule "2x_Cable_Up"
Item Switch_forRule_2x_Cable_Up_Command received command
GENIE_MINI_UP.sendCommand(ON)
rule "3x_Cable_Up"
Item Switch_forRule_3x_Cable_Up_Command received command
rule "4x_Cable_Up"
Item Switch_forRule_4x_Cable_Up_Command received command
rule "5x_Cable_Up"
Item Switch_forRule_5x_Cable_Up_Command received command
rule "2x_Cable_DOWN"
Item Switch_forRule_2x_Cable_DOWN_Command received command
GENIE_MINI_DOWN.sendCommand(ON)
rule "3x_Cable_DOWN"
Item Switch_forRule_3x_Cable_DOWN_Command received command
rule "4x_Cable_DOWN"
Item Switch_forRule_4x_Cable_DOWN_Command received command
rule "5x_Cable_DOWN"
Item Switch_forRule_5x_Cable_DOWN_Command received command
