Hello, is there a way to disable the auto discorvery in PaperUI for all bindings at once?
It should just put things in the inbox if i manually trigger the discovery function of a binding.
I tried this in the karaf console without success:
I also asked this once, because in some binding readme’s, the author wrote:
Blockquote
The binding can auto-discover the Onkyo AVRs present on your local network. The auto-discovery is enabled by default. To disable it, you can create a file in the services directory called onkyo.cfg with the following content:
org.openhab.onkyo:enableAutoDiscovery=false
This configuration parameter only controls the Onkyo AVR auto-discovery process, not the openHAB auto-discovery. Moreover, if the openHAB auto-discovery is disabled, the Onkyo AVR auto-discovery is disabled too.
Does anyone found a solution? I would also really like to disable the auto discovery for some bindings, like the hue binding. I’ve added my things manually and am getting now log entries like:
Discovery Result with UID ‘hue:bridge:########’ has been added.
Discovery Result with UID ‘hue:bridge:########’ has been removed.
I am interested in this topic too. According to the documentation it is possible to disable background discovery for bindings by setting discovery.hue:background=false in your runtime.cfg. I have not tested it yet.
Thanks glad to know it wasn’t just me! It isn’t more of an annoyance in the logs. I will probably not worry about it at the present moment. I will keep it on the list though for future.
i found a work around. I renamed the channels in my hue items file. Once the channels match what paper ui thinks they should be called then it quits showing them in the inbox.
named like this: hue:0220:1:8:xxxxxx
where xxx is brightness, color, etc.
You may have to change your thing file also. But This got rid of the auto discovery.
You have to look at your paper UI. Under the configuration --> things. Click on the Hue gateway get the serial number.
Put the serial number of the hue bridge in your thing files: Bridge hue:bridge:00178827d80b
After this use that in your channel configs: channel=“hue:0220:00178827d80b:1:brightness”
Your light id declarations are fine. This is how I got the inbox to quit filling. But you have to use the serial number of the bridge in the things file.
