Are you concerned about the memory footprint of those bundles, or the CPU consumption? If the latter, as long as you don’t have VS Code configured to use LSP (assuming you’re even using VS Code in this particular deployment), I doubt there’s much to worry about. If the former, then just disabling the bundles might not do much to reduce the memory footprint.
