I’ve receive a lot of logs because my trick with Tasmota. (I’ve created short version of mqtt message).
[WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Switch1' in '{"Switch2":"OFF"}'
I am trying to disable this messages in logs.
I’ve added section in userdata/etc/org.ops4j.pax.logging.cfg file:
log4j2.appender.out.filter.pirtransform.type = RegexFilter
log4j2.appender.out.filter.pirtransform.regex = .*Executing the JSONPATH-transformation failed.*
log4j2.appender.out.filter.pirtransform.onMatch = DENY
log4j2.appender.out.filter.pirtransform.onMisMatch = ACCEPT
But it doesn’t work. I’ve based on other topics and event bus filters. What is the right way to filter transformation logs?
