Hi I’m after some suggestions how to improve my temperature monitoring setup.
I’ve currently got a collections of temperature sensors arround the house, some are Bluetooth via openmqttgateway and some are the Dallas one wire via a mysensors gateway and a couple of others. I’ve got these in two groups as averages for upstairs and downstairs, then use one of these depending on time of day as my heating thermostat with a sonoff 4channel Pro relay replacing the old stat stuck in one room.
That works well except, the other day the Bluetooth gateway(openmqttgateway) died and needed replacing, what I wanted to happen was the averages to ignore these while it was down. I adding datetime updates to all the sensors so I could tell when they last changed and did a rule so if these hadn’t changed for 20 minutes I thought I’d disable the item. I’ve got some rules which disable http things if they are ping able, however I quickly realised items can’t be enabled/disabled in the same way.
Are my only options:
Live with the possibly that a dead battery in a bt sensor could skew the averages
Manually calculate the average on a timer or something
I’m using 3.1 in a Docker container.
