[DISCONTINUED] Tado Binding
@bennYx0x: Can you post your Dropdown how you update the timer?
Of course I can change the timer value to any number but how do you update it correctly so that tado app recognise the the timer setting?
EDIT: Please see the initial text. Due to a published tado binding today at the eclipse market place, it doesn’t make sense to continue investing time into this binding.
Hi Benjamin
Agree that just one binding should do it. Thanks for your effort, much appreciated :smiley::+1:
Hi Benjamin,
I would very much appreciate using your binding. But before I spend a lot of money for some Tado radiator thermostats, I would like to have my following questions answered.
Currently I am driving some Danfoss LC-13 zwave thermostats which I can control in a very flexibla way.
Within openhab2 I implemented some rules that prioritize the latest action whether this was a command sent by a rule to a thermostat or a manual command which changed the temperature using the thermostat’s knobs. Besides this my window sensors always send 4° C (or an OFF command) via rules to to the thermostats in the room where a window is opened and switch the valves back to the latest temperature that was set just before the first window has been opened. I can send commands to the thermostats using openhab rules (cron controlled and window sensor controlled) and I can also change the temperature manually whenever somebody likes to use the theromstat’s knobs instead of openhab.
I would like to know if this kind of controlling is also possible with Tado valves. Therefore it is necessary that they accept commands coming from the binding regardless if someone has changed the temperature manually just seconds before. And it is also necessary that someone can change the temperature manually by simply turning a valve’s knob without the need to deactivate something within openhab or within Tado Internet bridge or via Tado app. Furthermore I need to read the currently set temperature before the sensor triggered rules fire their OFF command.
Best regards,
Frank
Hello Frank,
I am not working on this binding anymore. Please see the initial post and search for the other tado binding thread.
BR
Ben
Hi Frank
I come from using Danfoss LC-13 in my previous home (left 10 of them with my ex-wife, both decisions mutually wise). I have recently bought the Tado and are quite satisfied with them so far. The binding Benjamin created worked really well, but I support his decision to discontinue to avoid working on two identical bindings. I have managed to implement the other (new) binding, although not fully using rules on them yet - only relying on the schedule within the Tado app.
I will recommend the Tado over Danfoss any day, The App and remote connection it’s a clear win. Secondly that you can access other info such as settemp, current temp, humidity, actual heatflow, etc.
Hopefully answering some of your questions, I have just tested updating in the App, secondly in OpenHAB, then manually on thermostat and back in App. Everything is syncronised across app, thermostat and OpenHAB, I did give it a minute between each update to ensure it was done outside of the refreshrate.
Let me know if this answers your questions? Perhaps we should take further discussion on the other binding thread.
/Anders
Hi Bejamin,
sorry, I thought the new one was also yours.
Hi Andres,
it does! Thanks very much.
Yes, you’re right.
Hm, the new binding from Dennis Frommknecht seems to cause a lot of trouble (see: Tado° Binding - #7 by dfrommi)
As I am already facing a lot of problems with cron based rules (see: cron rules stop working every few days Ā· Issue #4130 Ā· eclipse-archived/smarthome Ā· GitHub)
I will not use the new binding. Therefore my question: Did anybody face this kind of problems with the discontinued binding?
Hi Frank,
could you please be more specific about the lot of trouble? I’m not aware of any deal beakers. Thanks
Hi Dennis,
what I meant was: ā€žSo far I couldn’t find a way to reliably reproduce the leak problem.ā€œ
Ah ok, thanks. I’m currently working on a fix, so that’s hopefully solved soon.
Nevertheless, it doesn’t seem to impact functionality.
Hello guys,
Is this binding discontinued? No developing anymore or what’s the plan? I’v used the binding from the beginning and don’t have any issues.
Does anyone now if it is maybe possible to see the relay status of the thermostat in openhab?
Hey Thetmar,
correct, I am not actively developing on this binding anymore, even though I still use it still it fits my needs. See the initial post for more information, since you might want to switch to the published tado binding from Dennis.
