I´m trying to add Max thermostats to my openhab installation. I installed the binding (2.0.0.201701112020) and it connects to the cube:
2017-01-12 10:35:12.309 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection… to 192.168.34.224 port 62910
2017-01-12 10:35:22.316 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Start MAX! Cube discovery
2017-01-12 10:35:22.330 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Run MAX! Cube discovery
2017-01-12 10:35:22.428 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - MAX! Cube found on network
2017-01-12 10:35:22.430 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Found at : 192.168.34.224
2017-01-12 10:35:22.431 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Serial : NEQ1206731
2017-01-12 10:35:22.433 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - RF Address: 172816
2017-01-12 10:35:22.434 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Firmware : 01.13
2017-01-12 10:35:27.441 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Done receiving discovery messages.
But when I try to add things in paper UI it doesn´t find anythings and gives an exception in the logs (DEBUG):
2017-01-12 10:35:27.447 [INFO ] [nternal.handler.MaxCubeBridgeHandler] - Start MAX! inclusion mode for 60 seconds
2017-01-12 10:35:27.451 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types ‘[max:thermostat, max:thermostatplus, max:wallthermostat, max:ecoswitch, max:shuttercontact]’ on ‘MaxDeviceDiscoveryService’!
java.lang.NullPointerException
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.deviceInclusion(MaxCubeBridgeHandler.java:291)
at org.openhab.binding.max.internal.discovery.MaxDeviceDiscoveryService.startScan(MaxDeviceDiscoveryService.java:107)
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:199)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:381)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:357)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:216)
at org.eclipse.smarthome.io.rest.core.discovery.DiscoveryResource.scan(DiscoveryResource.java:84)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[10:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Though I can’t directly re-produce it, but due to a recent change indeed, there is indeed a chance that this java.lang.NullPointerException error can happen. when you start inclusion mode.
However, this most likely has little to do with the normal discovery of the thermostats connected to your cube.
From the log it seems
You had in the discovery result at least once have the cube itself. (>> correct??)
You triggered the discovery via paperUI
You have the cube already in the things list?
Would you mind setting the log more verbose. Execute in karaf log:set DEBUG org.openhab.binding.max log:display org.openhab.binding.max
Your assumptions (1-2) are right. The Cube is in the item list.
The log was in trace mode, I made a new one in debug but couldn´t see any differences:
2017-01-13 08:05:49.715 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection… to 192.168.34.224 port 62910
2017-01-13 08:06:02.037 [INFO ] [nternal.handler.MaxCubeBridgeHandler] - Start MAX! inclusion mode for 60 seconds
2017-01-13 08:06:02.045 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types ‘[max:thermostat, max:thermostatplus, max:wallthermostat, max:ecoswitch, max:shuttercontact]’ on ‘MaxDeviceDiscoveryService’!
2017-01-13 08:06:02.079 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Start MAX! Cube discovery
2017-01-13 08:06:02.080 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Run MAX! Cube discovery
2017-01-13 08:06:02.717 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - MAX! Cube found on network
2017-01-13 08:06:02.718 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Found at : 192.168.34.224
2017-01-13 08:06:02.719 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Serial : NEQ1206731
2017-01-13 08:06:02.719 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - RF Address: 172816
2017-01-13 08:06:02.720 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Firmware : 01.13
2017-01-13 08:06:07.726 [DEBUG] [nal.discovery.MaxCubeBridgeDiscovery] - Done receiving discovery messages.
2017-01-13 08:06:19.733 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection… to 192.168.34.224 port 62910
2017-01-13 08:06:49.750 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Open new connection… to 192.168.34.224 port 62910
Yes, I’ve submitted a fix for the NPE error that you encounter. It was merged this morning, so I think it will be available later today in the OH2 build
However… that does not fix the real issue I think you have
These lines indicate you are not connecting well to your cube for communication of messages.
Can it be that you have other software connecting at the cube as well (cube only can accept 1 connection)?
Can you restart your cube to see if than it is discovering the devices.
Wow - thanks for that superfast help. I´ll try if it works as soon as the bujild is available.
Regarding the new connection: I´ve set the permanent connection to false because I was still adding devices via the Cube directly, when I change that to true it connects only once.
