I’m trying to add PlantLink support into OpenHAB via their API, and need to display epoch time as a DateTime string. Currently the item gets populated (via the HTTP binding & JSONPATH) as: 1466886884
I’d like to either display it as DateTime, or use a rule to convert it to a DateTime string, then display it via another item. Either option would work.
Create a Number Item which gets populated with the epoch.
Create another DateTime Item which will get the displayable version.
rule "Parse DateTime"
Number Epoch changed
ReadableDate.sendCommand(new DateTimeType(Calendar::getInstance.setTimeMillis((Epoch.state as DecimalType).longValue)
Thanks for the rule @rlkoshak
I’ve created an item which receives the epoch number, and another item which will display it. I’ve also created rules for the conversion. But it’s not working right as of yet. Also, looking at the rule above, it looks like there’s 2 missing “)”'s
Here’s what I’ve got so far, is this correct?
rule Plant0 epoch
Number Plant0_Updated_Raw changed
Plant0_Updated.sendCommand(new DateTimeType(Calendar::getInstance.setTimeMillis((Epoch.state as DecimalType).longValue)))
@rlkoshak I’m not seeing any errors in the log files. Also I’m using vi, but with the openhab syntax highlighting. The rule seems to look ok to me. Do you know what imports I should be using? I’m assuming DecimalType, would I also need an import for Time?
Here’s the rule currently:
rule Plant0 epoch
logInfo("Plantlink", "Plant0: Updating Epoch Time")
Plant0_Updated.sendCommand(new DateTimeType(Calendar::getInstance.setTimeMillis((Plant0_Updated_Raw.state as DecimalType).longValue)))
I’ll open it up in designer and make sure it looks ok.
Vi does syntax highlighting but not syntax checking. Designer does a lot more thorough checking. For example, if you hve a typo in an Item name, vi will happly let it stand but Designer will point out the error.
rule "Plant0 epoch"
I’m wondering, shouldn’t Number (above) be Item instead?
Alright, I’ve changed the Number to Item, in the rule. It’s not working but I am getting an error this time. Here’s the rule:
import java.util.Calendar
import org.openhab.core.library.types.DecimalType
rule "Plant0 epoch"
Item Plant0_Updated_Raw changed
And the error:
2016-07-13 18:12:14.885 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'plant_epoch_conv.rules'
2016-07-13 18:16:01.953 [INFO ] [openhab.model.script.Plantlink] - Plant0: Updating Epoch Time
2016-07-13 18:16:02.184 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Plant0 epoch'
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getConstructor(JavaReflectAccess.java:90) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(XbaseInterpreter.java:511) ~[na:na]
at sun.reflect.GeneratedMethodAccessor501.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:751) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
at sun.reflect.GeneratedMethodAccessor478.invoke(Unknown Source) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.GeneratedMethodAccessor483.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor482.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
When the Rules DSL is unable to convert something into a valid state it throws a NullPointerException. I wish they had created a separate and more descriptive exception for this case because NullPointer is misleading.
I think it doesn’t like the longValue. I suspect it can’t handle the raw DateTimeType and it needs a String. Or one of the other conversions isn’t working.
Try (the line is getting long so I’ll break it up some):
val Number epoch = Plant0_Updated_Raw.state as DecimalType // Note, DecimalType is a Number
val Calendar cal = Calendar::getInstance.setTimeMillis(epoch.longValue)
val DateTimeType dtt = new DateTimeType(cal)
Plant0_Updated.sendCommand(dtt.toString)
If it still doesn’t work, intersperse each of the above lines with logInfo statements so you can see which specific line it fails on.
I would have to agree, I wish it wasn’t so deceptive, makes issues like these hard to troubleshoot.
I’ve updated the rule as above, but added in some logInfo statements to help determine where the problem is. Here’s the rule:
rule "Plant0 epoch"
logInfo("Plantlink", "Plant0: Epoch Convert Start")
logInfo("Plantlink", "Plant0: Step 1")
logInfo("Plantlink", "Plant0: Step 2")
logInfo("Plantlink", "Plant0: Step 3")
logInfo("Plantlink", "Plant0: Sending update to Plant0_Updated")
and the error:
2016-07-14 10:46:53.496 [INFO ] [openhab.model.script.Plantlink] - Plant0: Epoch Convert Start
2016-07-14 10:46:53.614 [INFO ] [openhab.model.script.Plantlink] - Plant0: Step 1
2016-07-14 10:46:53.865 [INFO ] [openhab.model.script.Plantlink] - Plant0: Step 2
2016-07-14 10:46:54.014 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Plant0 epoch': The name '<XFeatureCallImplCustom>.setTimeMillis(<XMemberFeatureCallImplCustom>)' cannot be resolved to an item or type.
Looks like you were right, it doesn’t like the longValue (line).
In Designer, this sort of error should have been highlighted in red. And if one types cal.<ctrl><space> it will bring up a list of valid completions, one of which would be setTimeInMillis.
I can’t always do this, about 80% of my replies are from my phone. Lots of errors like this get past me as a result.
Log out dtt.toString. I think this error is that it can’t convert that to a format Plant0_Updated understands. It doesn’t make sense but that is what the error implies.
import org.joda.time.*
import org.openhab.core.library.types.*
rule "Plant0 epoch"
System started or
var String date = new SimpleDateFormat("yyyy/MM/dd HH:mm:ss").format(new java.util.Date(((Plant0_Updated_Raw.state as DecimalType) * 1000).longValue))
Plant0_Updated.postUpdate(date)
