Hi all,
unfortunately another beginner question (openhab 3) which should be just easy to answer:
- The item is defined as number only (no unit)
- In the Item definition, the State definition → Pattern is defined as %.0f
- In Model + Items, the real value shows absolute correctly with the desired formatting
- In the widgets, as well as in the own definition of a widget, always all the decimals are shown.
How can the applied Pattern be used in widgets?
I know, I can get rid of it in the widget by rounding the value, however that is not a good solution since we have the item definition.
In my own widget yaml, I use
=items[props.item2].state
first I thought I use the wrong property, but since also the other widgets show the same behaviour I’m a bit confused.
One solution would be to define own widgets for everything, but thats not the reason I have choosen Openhab
Any help is appreciated
