Distance between location items
Hi Guys,
i want to calculate the distance between two different Location Items. A i right that i have to use a rule like this ?
https://github.com/openhab/openhab/blob/master/bundles/core/org.openhab.core.library/src/main/java/org/openhab/core/library/items/LocationItem.java
or this the definition of a location item?
in case i can use it to calc the distance what would be my two items? one would obiously the away item
Yes
I don’t understand the question or you don’t understand OH. You would define two Location Items and they will be populated somehow (Own Tracks?). In a rule you then use:
val distanceM = (myLocation1 as LocationItem).distanceFrom(myLocation2 as LocationItem)
Oh didnt know that it would be that simple. thanks a lot
