I have implemented the DIY MORE ESP32 DHT11 Soil Sensor into my openhab through tasmota and autodiscovery. I get a temperature and a status item with a range ao 1-100. None of the items shows a useable reaction to moisture. The values change (86-100) but not but not in accordance to the moisture. Actually one value should be the battery status an the other the moisture.
Has anyone this soil sensor in use an can tell me how to configure it?
I found the solution. In Tasmota menu I had to change the Type from ESP32 to DIYmore.
