This discussion is related to my PR #4775 in OH1.
Currently DMX data is only send to the output when at least one channel changed. The following is copied from the PR:
I have incorporated all comments. However, after re-reading E1.11 (DMX 512) and E1.31 (sACN) as well as ArtNet, I come to the conclusion that the “never-refresh-policy” is plain wrong when it comes to standards compliance.
E1.11 states for DMX512 that there is a continous data stream (with a maximum MARK before BREAK of 1s), and defines that longer periods are considered as Data Lost (8.9). The standard does not define how a receiver should behave if that occurs, besides that it should remain operational for at least 60s. So after 60s without signal a standard compliant receiver could even turn off (9.2).
E1.31 defines that if the output is not changing, the last packet should be re-transmitted three times. After that the sender is allowed to pause sending for 800-1000ms (6.6.2).
ArtNet defines that non-changing DMX data should be retransmitted at approximately 4s intervals, but it is recommended for compatibility with sACN to re-transmit after 800-1000ms (chapter ArtDmx, p. 46).
The PR changes the default behaviour to “send always”, which is compatible with all protocols. With a new configuration option this can be changed to suppress repeated transmissions for 800ms or to the current behaviour.
@watou requested your thoughts on this.
Best regards
