I would like to use a map transformation for the rain fall channel in the Weather Underground binding as sometimes, the binding returns a non numeric value (-, null). I even got a negative value once. The channel returns a number and a map returns a string. So it seems to me that all possible values would have to be mapped, which is impractical. Does this make sense? Alternatively, I could try a JS transformation, return a parseable value (parseInt), or some default, (0.00) if it can’t be parsed (-, null, etc.).
Thoughts?
For number values, you can map ranges to strings such as
[08:12:33] root@openhabianpi:/etc/openhab2/transform# cat airquality_outer.scale
[0..50]=Gut
[51..100]=Mässig
[101..150]=Ungesund fuer Sensitive
[151..200]=Ungesund
[201..300]=Sehr ungesund
[300..10000]=Gefährlich
-=keine Daten
I wanted to point you at the transformation docs but quickly looking at these I didn’t see that mentioned. Must have gotten lost somehow during docs rework.
Right, sorry I should have mentioned that.
Number AirQuality "Air Quality Index [SCALE(airquality_outer.scale): %s]" <carbondioxide> (Status,Lueftung)
Thanks for the reply and I also looked at the docs and couldn’t find an answer. I’d rather not map or scale ranges to different values, so I think I’ll use a JS transformation.
SCALE tranformation is a mapping of number ranges to a output string only used in UIs, so you would in my example see “Air Quality Index … Mässig” in sitemap/UI whenever the item value is anywhere from 51 to 100.
Which I thought is what you were looking for. That’s no scaling, it does not change the values. Just try it.
It is just a prebuilt JS scriptlet. But if you do can and want to code JS yourself, feel free.
Ok, I understand. I’ll give it a try.
