Hello and good evening,
A few days ago I bought a Z-Wave.Me Wall Controller, more precisely a ZME_06443: Wall Controller.
After I have integrated this via the inbox of the Paper UI, 2 channels are displayed to me.
Channels
Scene Number
zwave:device:xxxxxxxx:node36:scene_number
Batterieladung
zwave:device:xxxxxxxx:node36:battery-level
I created these items as follows:
Number ZWaveNode036SceneNumber "Scene number" {channel="zwave:device:d7814888:node36:scene_number"}
Number ZWaveNode036BatteryLevel "Batterieladung" {channel="zwave:device:d7814888:node36:battery-level"}
With this switch you have the option of pressing the rocker up and down once.
I would now like to use this as a completely normal switch, means the rocker switch upwards light on, the rocker switch downwards and the light should go off again. Unfortunately, I have no idea how to do this. I am somehow fully on the hose, because I have no idea how to get the switch command (by pressing the switch locally) into my system.
As long as I press one of the two rocker switches, I don’t see anything in the log. With a triple click the log will show the following:
2020-10-30 23:27:17.674 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:xxxxxxxx:node36' has been updated.
My Openhab system runs on a Raspberry PI in connection with a zme_uzb1 stick.
I have set the following parameters via the Paper UI:
Configuration parameters:
Parameter 10= 50
Parameter 11= No
Parameter 13= Switch ON, OFF and dim Basic Set
Parameter 14= Disabled
Parameter 15= Switch OFF Only
Parameter 20= No
Association Groups:
Parameter 1= Controller
Parameter 2=
Wakeup Configuration:
Wakeup Interval= 604800
I hope that I can help myself!
greetings Didschu
Here I have a couple of links with a little more information.
https://doc.eedomus.com/en/index.php/Wi … ZME_06443)
https://doc.eedomus.com/files/Z-WAVE.ME … ual_US.pdf
https://opensmarthouse.org/zwavedatabase/148
