Text label="WC1" {
Frame label="test" {
Switch item=Light_WCBig_Ceiling
Text label="WC2" {
Frame item=Temp_WCBig {
When I toggle ‘Light_WCBig_Ceiling’, within “WC1” page, the update of the icon is performed; no refresh is necessary on the user interface (either iOS or Web Basic UI).
However if I toggle ‘Light_WCBig_Ceiling’, within “WC2” page, the update of the icon is not performed.
Nevertheless, if I refresh the page, navigate back, and in again, the change is then shown.
The only diference here is the use of item=Temp_WCBig in the Frame declaration.
Allegedly, the use of items in frame declarations is possible, but I wasn’t exiting the different behaviour.
Is there any thing wrong with this configuration?
Shouldn’t the reaction to the toggle be consistent?
Once again, when I toggle ‘Light_WCBig_Ceiling’, within “WC1” page, the update of the icon is performed; no refresh is necessary on the user interface (either iOS or Web Basic UI).
However if I toggle ‘Light_WCSmall_Ceiling’, within “WC2” page, the update of the icon is not performed.
Once again, if I refresh the page, navigate back, and in again, the change is then shown.
Is this the expected behaviour!?
Do you have any ideias about what’s going on?
You are right. I forgot to mention that. Either Classic UI or native iOS present the same behaviour.
Should I fill an issue in the repo you suggested, or somewhere else, since this behaviour is transversal to other UI?
