Maybe the Zwave device it’s self needs reset or a bit more time for everything to come back?
Possibly… Will shutdown it all once more and see.
@jr555se: Since openhab-cli clean-cache does not work with docker you may want to keep this command handy, as I had to dig a bit to find it.
sudo rm -rf /var/lib/openhab2/cache/* && sudo rm -rf /var/lib/openhab2/tmp/*
Very helpful to use anytime OH starts acting weird or you see strange logs. It’s my first step in troubleshooting and for my system it’s usually the only needed.
If you still cannot control the devices I would delete one of them from OH then rediscover it. Maybe that is all that’s needed for control but I would test with just one and do the rest if it works.
yeah, I seem to be able to control now. Takes long time though so I think the mesh needs a reset which will happen tonight.
So, to recap all that was needed was to remove the reference to the old rest-doc in the addons file “/home/openhab/userdata/config/org/openhab”
then clean the cache and tmp directories which for me is:
“/home/openhab/userdata/tmp/” and “/home/openhab/userdata/cache/”
Hoping noone else gets my issues but just in case…
Thank you @H102 and @Bruce_Osborne my family is happy now when its up again. Looking fwd to use the new and updated rule engine.
//JR
Just to add a little bit if info. When you start a new container, it checks to see if the version of OH running is different than the version indicated in userdata/etc/version.properties. If they differ, the script will back up userdata and perform a clear the cache automatically before stressing OH. For a normal upgrade, manually clearing the cache would be redundant. However, because if the REST API issue, a separate clear the cache was necessary to deal with that. But it’s not usually required.
This would be the complete solution (for those using Docker) for others that do not want to read all post.
