I’m seeing openhab restart recently…In portainer I see:
|2020-12-23 14:39:25|network|Container connected to host network|
|2020-12-23 14:39:25|network|Container disconnected from host network|
|2020-12-23 14:39:24|container|Container openhab exited with status code 137|
But nothing is in the openhab logs apart from the start up messages:
2020-12-23 14:39:09.667 [INFO ] [clipse.smarthome.model.script.Node19] - Node19 Changed to Online
2020-12-23 14:39:17.393 [INFO ] [smarthome.model.script.Paradox State] - Container state: running
2020-12-23 14:39:17.419 [INFO ] [smarthome.model.script.Camera Events] - Container state: running
**2020-12-23 14:39:18.409 [INFO ] [arthome.model.script.Mosquitto State] - Container state: running**
**2020-12-23 14:39:44.526 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher 'aes256-ctr' not available**
2020-12-23 14:39:44.570 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher 'aes192-ctr' not available
2020-12-23 14:39:45.141 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher 'aes256-ctr' not available
2020-12-23 14:39:45.142 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher 'aes192-ctr' not available
2020-12-23 14:39:49.900 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Pacific/Auckland'.
2020-12-23 14:39:49.913 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '-41.21744137100655,174.90742438161374'.
2020-12-23 14:39:49.922 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_NZ'.
I think the 2020-12-23 14:39:44.526 is the first entry upon restart.
Are there any other logs i can look at?
The docker logs are particularly unhelpful just shows the container starting:
2020-12-22T20:07:18.570323901Z org.ops4j.pax.url.wrap [org.ops4j.pax.url.commons.handler.HandlerActivator] DEBUG : Handler for protocols [wrap] started
2020-12-23T01:39:26.357407839Z ++ test -t 0
2020-12-23T01:39:26.361512442Z ++ echo false
2020-12-23T01:39:26.361555372Z + interactive=false
2020-12-23T01:39:26.361569718Z + set -euo pipefail
2020-12-23T01:39:26.361582596Z + IFS='
2020-12-23T01:39:26.361594811Z '
2020-12-23T01:39:26.361611450Z + '[' limited = unlimited ']'
2020-12-23T01:39:26.361627450Z + rm -f /openhab/runtime/instances/instance.properties
2020-12-23T01:39:26.402471541Z + rm -f /openhab/userdata/tmp/instances/instance.properties
2020-12-23T01:39:26.423361205Z + NEW_USER_ID=1000
2020-12-23T01:39:26.424509449Z + NEW_GROUP_ID=1001
2020-12-23T01:39:26.426238393Z + echo 'Starting with openhab user id: 1000 and group id: 1001'
2020-12-23T01:39:26.427401812Z Starting with openhab user id: 1000 and group id: 1001
2020-12-23T01:39:26.436141624Z + id -u openhab
2020-12-23T01:39:26.465222958Z + initialize_volume /openhab/conf /openhab/dist/conf
2020-12-23T01:39:26.466156832Z + volume=/openhab/conf
2020-12-23T01:39:26.466618370Z + source=/openhab/dist/conf
2020-12-23T01:39:26.475211987Z ++ ls -A /openhab/conf
2020-12-23T01:39:26.481830080Z + '[' -z 'a.out
2020-12-23T01:39:26.481885907Z .git
2020-12-23T01:39:26.481899930Z .gitattributes
2020-12-23T01:39:26.481912401Z html
2020-12-23T01:39:26.481924156Z icons
2020-12-23T01:39:26.481938618Z items
2020-12-23T01:39:26.481953413Z persistence
2020-12-23T01:39:26.481968036Z README.txt
2020-12-23T01:39:26.482015068Z rules
2020-12-23T01:39:26.482030152Z scripts
2020-12-23T01:39:26.482043282Z services
2020-12-23T01:39:26.482055436Z sitemaps
2020-12-23T01:39:26.482066225Z sounds
2020-12-23T01:39:26.482076888Z things
2020-12-23T01:39:26.482087646Z transform
2020-12-23T01:39:26.482100591Z .vscode' ']'
2020-12-23T01:39:26.482133976Z + initialize_volume /openhab/userdata /openhab/dist/userdata
2020-12-23T01:39:26.482164950Z + volume=/openhab/userdata
2020-12-23T01:39:26.482178645Z + source=/openhab/dist/userdata
2020-12-23T01:39:26.483909633Z ++ ls -A /openhab/userdata
2020-12-23T01:39:26.488569609Z + '[' -z 'backup
2020-12-23T01:39:26.488621178Z cache
2020-12-23T01:39:26.488635888Z config
2020-12-23T01:39:26.488649865Z etc
2020-12-23T01:39:26.488662993Z habmin
2020-12-23T01:39:26.488676059Z jsondb
2020-12-23T01:39:26.488688890Z logs
2020-12-23T01:39:26.488702202Z openhabcloud
2020-12-23T01:39:26.488715403Z persistence
2020-12-23T01:39:26.488727993Z temp
2020-12-23T01:39:26.488740813Z tmp
2020-12-23T01:39:26.488753614Z uuid
2020-12-23T01:39:26.488765774Z zwave' ']'
2020-12-23T01:39:26.490680723Z ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
2020-12-23T01:39:26.502114741Z + '[' '!' -z ']'
2020-12-23T01:39:26.502188292Z + chown -R openhab:openhab /openhab
2020-12-23T01:39:27.846668201Z + sync
2020-12-23T01:39:28.032682957Z + '[' -d /etc/cont-init.d ']'
2020-12-23T01:39:28.032755723Z + sync
2020-12-23T01:39:28.108769651Z + '[' false == false ']'
2020-12-23T01:39:28.109535734Z ++ IFS=' '
2020-12-23T01:39:28.109566831Z ++ echo gosu openhab tini -s ./start.sh
2020-12-23T01:39:28.111496027Z + '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
2020-12-23T01:39:28.111593155Z + command=($@ server)
2020-12-23T01:39:28.111625007Z + exec gosu openhab tini -s ./start.sh server
2020-12-23T01:39:28.150722514Z Launching the openHAB runtime...
2020-12-23T01:39:35.670609618Z org.ops4j.pax.url.wrap [org.ops4j.pax.url.commons.handler.HandlerActivator] DEBUG : Handler for protocols [wrap] started
