this time I also have issues with the 3.3.0 docker image after upgrading from 3.2.0.
It won’t start, last thing I see is
Launching the openHAB runtime...
The upgrade script reported that it was successful but then nothing happens. I already checked that the mounted volumes are writeable and also had a look for a “/usr/share/openhab/addons” folder without luck. Also I could not increase the log output after adding
<AppenderRef ref="STDOUT"/>
to log4j2.xml…
This is the log output I got from docker:
docker-compose up
Starting openhab-latest ... done
Attaching to openhab-latest
openhab-latest | + IFS='
openhab-latest | '
openhab-latest | ++ ls -d /usr/lib/jvm/temurin-11-jdk-amd64
openhab-latest | + export JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-amd64
openhab-latest | + JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-amd64
openhab-latest | + '[' limited = unlimited ']'
openhab-latest | + /etc/ca-certificates/update.d/adoptium-cacerts
openhab-latest | /etc/ssl/certs/adoptium/cacerts successfully populated.
openhab-latest | + capsh --print
openhab-latest | + grep -E Current:.+,cap_net_admin,cap_net_raw,.+
openhab-latest | + rm -f /openhab/runtime/instances/instance.properties
openhab-latest | + rm -f /openhab/userdata/tmp/instances/instance.properties
openhab-latest | Starting with openhab user id: 1032 and group id: 100
openhab-latest | + NEW_USER_ID=1032
openhab-latest | + NEW_GROUP_ID=100
openhab-latest | + echo 'Starting with openhab user id: 1032 and group id: 100'
openhab-latest | + id -u openhab
openhab-latest | + initialize_volume /openhab/conf /openhab/dist/conf
openhab-latest | + volume=/openhab/conf
openhab-latest | + source=/openhab/dist/conf
openhab-latest | ++ ls -A /openhab/conf
openhab-latest | + '[' -z 'automation
openhab-latest | coverage
openhab-latest | html
openhab-latest | icons
openhab-latest | items
openhab-latest | misc
openhab-latest | persistence
openhab-latest | rules
openhab-latest | scripts
openhab-latest | services
openhab-latest | sitemaps
openhab-latest | sounds
openhab-latest | things
openhab-latest | transform' ']'
openhab-latest | + initialize_volume /openhab/userdata /openhab/dist/userdata
openhab-latest | + volume=/openhab/userdata
openhab-latest | + source=/openhab/dist/userdata
openhab-latest | ++ ls -A /openhab/userdata
openhab-latest | + '[' -z 'backup
openhab-latest | cache
openhab-latest | Californium.properties
openhab-latest | config
openhab-latest | etc
openhab-latest | jsondb
openhab-latest | kar
openhab-latest | logs
openhab-latest | marketplace
openhab-latest | mqtt
openhab-latest | mqttembedded.bin
openhab-latest | openhabcloud
openhab-latest | secrets
openhab-latest | tmp
openhab-latest | uuid' ']'
openhab-latest | ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
openhab-latest | + '[' '!' -z ']'
openhab-latest | + chown -R openhab:openhab /openhab
openhab-latest | + sync
openhab-latest | + '[' -d /etc/cont-init.d ']'
openhab-latest | + '[' false == false ']'
openhab-latest | ++ IFS=' '
openhab-latest | ++ echo gosu openhab tini -s ./start.sh
openhab-latest | + '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
openhab-latest | + command=($@ server)
openhab-latest | + exec gosu openhab tini -s ./start.sh server
openhab-latest | Launching the openHAB runtime...
This is my docker-compose.yml:
version: '2.2'
services:
openhab_service: #name of the service
container_name: openhab-latest
image: "openhab/openhab:latest"
restart: always
network_mode: host
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/TZ:/etc/timezone:ro"
- "/volume1/openhab/addons:/openhab/addons"
- "/volume1/openhab/conf:/openhab/conf"
- "/volume1/openhab/userdata:/openhab/userdata"
environment:
USER_ID: "1032"
GROUP_ID: "100"
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin -Djava.net.preferIPv4Stack=true"
LC_ALL: "de_DE.UTF-8"
LANG: "de_DE.UTF-8"
LANGUAGE: "de_DE.UTF-8"
Until now the docker image was running smoothly for years but now I’m stuck
I hope that somebody can help me, thanks!
