I am testing docker to run openHAB in a container.
So far it seems to work great.
Now I included my Enocean-USB-device.
--device "/dev/ttyUSB-Enocean01" \
--env EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB-Enocean01" \
When I docker run
my setup it works as expected.
The Enocean items work and change state when I press a Enocean button.
But when I docker restart openhab
I get this errors.
2018-09-15 21:06:41.878 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=419, bundle=236/mvn:org.openhab.binding/org.openhab.binding.enocean/1.13.0-SNAPSH│
or│OT]: Updating property serialPort of configuration org.openhab.enocean caused a problem: Serial port '/dev/ttyUSB-Enocean01' could not be opened. Available ports are: │
│org.osgi.service.cm.ConfigurationException: serialPort : Serial port '/dev/ttyUSB-Enocean01' could not be opened. Available ports are: │
│ at org.openhab.binding.enocean.internal.bus.EnoceanBinding.updated(EnoceanBinding.java:159) ~[?:?] │
│ at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) ~[9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1102) [9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1058) [9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [9:org.apache.felix.configadmin:1.9.4] │
│ at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4] │
20│ at java.lang.Thread.run(Thread.java:748) [?:?]
removing the container and docker run
again with the same config it works again.
I can reproduce this behavior.
An I missing something?
Why does restarting
the container not work, but rerunning
it does?
I also get this errors when restarting.
2018-09-15 21:06:34.361 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/whitelight.xml' in module 'org.eclipse.smarthome.binding.lifx' could not be parsed: The XmlConfigDescriptionProvider must not
be null!
java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlProvider.<init>(ThingTypeXmlProvider.java:81) ~[?:?]
at org.eclipse.smarthome.core.thing.xml.internal.XmlThingTypeProvider.createDocumentProvider(XmlThingTypeProvider.java:163) ~[?:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:180) ~[99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:205) ~[99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:351) [99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:337) [99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$4(XmlDocumentBundleTracker.java:332) [99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [99:org.eclipse.smarthome.config.xml:0.10.0.201809111909]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-09-15 21:06:34.363 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/bridge-types.xml' in module 'org.openhab.binding.avmfritz' could not be parsed: The XmlConfigDescriptionProvider must not be
null!
2018-09-15 21:06:34.362 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/thing-types.xml' in module 'org.openhab.binding.harmonyhub' could not be parsed: The XmlConfigDescriptionProvider must not be
null!
But this may be another issue.
