Documentation for SMHI binding on openHAB2 2.5.11
Regarding documentation for SMHI binding on openHAB2 2.5.11.
Channels in documentation (Smhi - Bindings | openHAB) are named in words rather than the actual channels that can be found in the Thing configuration in PaperUI.
Also, Max & Min Temperature and Max & Min Wind Speed should probably not be in the documentation since they are not discovered and available for use (according to Thing config in PaperUI).
That is for the openHAB 3 binding. Here is the v2 one.
Oh, my bad. Thanks!
Though, it seems that the comment on channel names applies for both 2.5.11 and 3.0.0. In order for the examples to relate to the interface, another column for the actual channel as it would be referenced in the items-file would be nice.
