I’m a stupid beginner in programming openHAB2 and don’t have any experience in programming openHAB1.
Actual I try to configure some rules. When I’ve a look to the REST API I find a nice example source code for creating rules.
“triggers”: [
“id”: “string”,
“label”: “string”,
“description”: “string”,
“configuration”: {},
“typeUID”: “string”
“conditions”: [
“id”: “string”,
“label”: “string”,
“inputs”: {},
“typeUID”: “string”
“actions”: [
“id”: “string”,
“label”: “string”,
“inputs”: {},
“typeUID”: “string”
“templateUID”: “string”,
“uid”: “string”,
“name”: “string”,
“tags”: [
“string”
“visibility”: “VISIBLE”,
“configurationDescriptions”: [
“name”: “string”,
“type”: “TEXT”,
“groupName”: “string”,
“pattern”: “string”,
“required”: false,
“readOnly”: false,
“multiple”: false,
“multipleLimit”: 0,
“unit”: “string”,
“unitLabel”: “string”,
“context”: “string”,
“label”: “string”,
“options”: [
“label”: “string”,
“value”: “string”
“filterCriteria”: [
“value”: “string”,
“name”: “string”
“limitToOptions”: false,
“advanced”: false,
“stepSize”: 0,
“minimum”: 0,
“maximum”: 0,
“default”: “string”
Some points I’ve already figured out and I’m able to create a simple rule.
My question is now, is there any detailed documentation for creating rules where every possibility of settings is described. Which commands are possible and so on.
Thanks for your help.
