Is this below item in correct syntax…?
I think I need at least change ohab:/ to mosquitto:/ as that is set on mqtt.cfg?
Item:
Dimmer masterbedr_blind1 “Rullgardin 1” { mqtt=">[ohab:/house/masterbedroom/rollerblind/0/set:command:*:${command}],<[ohab:/house/masterbedroom/rollerblind/0/status:state:default]" }
Sitemap:
Slider item=masterbedr_blind1
Trying to integrate this: http://www.instructables.com/id/Motorized-WiFi-IKEA-Roller-Blind/
mqtt.cfg:
mosquitto.url=tcp://localhost:1883
mosquitto.qos=1
mosquitto.retain=true
mosquitto.async=false
Getting messages:
[22:22:20] openhabian@openHABianPi:/etc/openhab2/sitemaps$ mosquitto_sub -d -h localhost -p 1883 -t "#"
Client mosqsub/3993-automaatio sending CONNECT
Client mosqsub/3993-automaatio received CONNACK
Client mosqsub/3993-automaatio sending SUBSCRIBE (Mid: 1, Topic: #, QoS: 0)
Client mosqsub/3993-automaatio received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/3993-automaatio received PUBLISH (d0, q0, r0, m0, ‘/house/masterbedroom/rollerblind/0/heartbeat’, … (9 bytes))
id=387814
Client mosqsub/3993-automaatio received PUBLISH (d0, q0, r0, m0, ‘myfirst/test’, … (5 bytes))
Hello
But the fully integration is little bit confusing… MQTT Binding is installed with Paper UI
