I have a Busch Jäger Powernet KNX Installation. Sent telegrams might get lost on powernet bus. Therefore you can define a so called “Gruppensprecher” to send an ACK when the telegram was received. The sender will repeat the telegram, if the ACK was not received in time.
Does the KNX bindung support this feature? Can send ACK, so act as a “Gruppensprecher” and/or repeat a telegram when ACK from an other devise was not received?
Bests,
Michael
