I recently upgraded to the 2.5.11.
Yesterday, I went to the greenhouse and the temps on the equipment had been reset to 100 degrees and the lights had been turned on. Not something we had done.
I spent some time last night working on some alerting. And looking through logs. Everything looked good when I signed off.
This morning, everything we reset to 100 and the lights were on again.
I found these entries in the logs:
This was the first odd entry. I had setup a way to record info at another farm of ours but we dont farm there now and I just haven’t turned off the code. It really doesn’t impact us. So this flipping to ON was very weird. And at midnight.
2021-01-20 23:42:22.370 [ome.event.ItemCommandEvent] - Item 'Midway_Pyganic_Trigger' received command ON
Right before that I had this entry in the openhab log:
2021-01-20 23:42:27.946 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Midway Nutrients Water Plants Counter': An error occurred during the script execution: Couldn't invoke 'assignValueTo' for feature JvmVoid: (eProxyURI: midwaywater.rules#|::0.2.2.2.0.0::0::/1)
Again, not a big deal as we dont use this anymore and didn’t think it was something that would harm anything…
Then the weird things start happening…
All of the settings in the greenhouse started changing or being changed. Here is just one example:
2021-01-20 23:42:42.049 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 82
2021-01-20 23:42:42.086 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 81.0 to 82
2021-01-20 23:42:42.609 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 83
2021-01-20 23:42:42.634 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 82 to 83
2021-01-20 23:42:42.991 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 84
2021-01-20 23:42:43.014 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 83 to 84
2021-01-20 23:42:43.311 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 85
2021-01-20 23:42:43.332 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 84 to 85
2021-01-20 23:42:43.568 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 86
2021-01-20 23:42:43.620 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 85 to 86
2021-01-20 23:42:43.898 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 87
2021-01-20 23:42:43.920 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 86 to 87
2021-01-20 23:42:44.078 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 88
2021-01-20 23:42:44.113 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 87 to 88
2021-01-20 23:42:44.367 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 89
2021-01-20 23:42:44.389 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 88 to 89
2021-01-20 23:42:44.577 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 90
2021-01-20 23:42:44.601 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 89 to 90
2021-01-20 23:42:44.775 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 91
2021-01-20 23:42:44.792 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 90 to 91
2021-01-20 23:42:45.030 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 92
2021-01-20 23:42:45.055 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 91 to 92
2021-01-20 23:42:45.223 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 93
2021-01-20 23:42:45.250 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 92 to 93
2021-01-20 23:42:45.424 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 94
2021-01-20 23:42:45.443 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 93 to 94
2021-01-20 23:42:45.599 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 95
2021-01-20 23:42:45.626 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 94 to 95
2021-01-20 23:42:45.851 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 96
2021-01-20 23:42:45.880 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 95 to 96
2021-01-20 23:42:46.080 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 97
2021-01-20 23:42:46.108 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 96 to 97
2021-01-20 23:42:46.268 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 98
2021-01-20 23:42:46.301 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 97 to 98
2021-01-20 23:42:46.493 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 99
2021-01-20 23:42:46.515 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 98 to 99
2021-01-20 23:42:46.876 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 100
2021-01-20 23:42:46.895 [vent.ItemStateChangedEvent] - Shutter1_Thermostat_SP_F changed from 99 to 100
2021-01-20 23:42:47.900 [ome.event.ItemCommandEvent] - Item 'Shutter1_Thermostat_SP_F' received command 100
2021-01-20 23:42:49.718 [ome.event.ItemCommandEvent] - Item 'SingleSpeedFan_Thermostat_SP_F' received command 98
2021-01-20 23:42:49.752 [vent.ItemStateChangedEvent] - SingleSpeedFan_Thermostat_SP_F changed from 97.0 to 98
2021-01-20 23:42:50.255 [ome.event.ItemCommandEvent] - Item 'SingleSpeedFan_Thermostat_SP_F' received command 99
2021-01-20 23:42:50.271 [vent.ItemStateChangedEvent] - SingleSpeedFan_Thermostat_SP_F changed from 98 to 99
2021-01-20 23:42:57.563 [ome.event.ItemCommandEvent] - Item 'SingleSpeedFan_Thermostat_SP_F' received command 100
2021-01-20 23:42:57.594 [vent.ItemStateChangedEvent] - SingleSpeedFan_Thermostat_SP_F changed from 99 to 100
2021-01-20 23:42:58.996 [ome.event.ItemCommandEvent] - Item 'SingleSpeedFan_Thermostat_SP_F' received command 100
It gets reset until it gets to 100.
Just trying to determine if this is something that could be triggered in openhab or if this is a hack or a card issue?
I will take my lashes as I dont run much security on the system. This looks like it would be done through the app in some way or a bot? Wow, that was some work by someone for whatever reason. I need to have them code some good stuff for me…
I tried to download the auth.log file but its very large and would not come down. Yesterday when I looked through there you can see where there are various login attempts.
I plan to pull the card and rebuild today. Maybe on 3. I will work to put in better security but thought I would share for some feedback.
Thanks!
