Does Zram stop SDCard failure when using InfluxDB and Grafana
The internal one or the stick ? USB sticks are the exact same tech as SD flash mem so this was to be expected. Read on here.
You have to be careful in moving as running databases will affect many areas of the system, e.g. system logging and swap space so you can still easily trash your internal SD that way.
