I’m having issues getting the Dome Z-Wave Plus Motion Sensor (here’s its database listing) to be recognized as a known device by my Aeotec Z-Stick (Gen5) and OpenHAB.
It’s a battery-powered sensor, which I’ve read means I’ll have to wake it several times after inclusion for it to communicate information like Manufacturer ID, etc. After digging, I found out that you wake it by pressing and holding its inclusion button for about a half-second; its face lights up when you do this, which I assume means it’s awake (can’t find any info on how long it stays awake, though). I’m not totally clear on when this process should take place: during inclusion (the Z-Stick has to be removed from the USB port before inclusion, then a button is pressed, etc.), or during Thing discovery in OpenHAB, but I’ve tried both.
I’m honestly not sure where the trouble is. I noticed that my Z-Stick Thing is missing quite a bit of information. Could this be a problem?
The logs show binary events for the motion sensor whenever I wave my hand in front of it/remain still (255 for waving hand, 0 for being still), and I’m not sure what I should be looking for in the logs outside of the obvious, but here goes, from Thing discovery and then on a bit:
2018-03-25 17:18:29.079 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:zipato_zp3102_00_000
2018-03-25 17:18:29.081 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:aeon_dsa38_00_000
2018-03-25 17:18:29.083 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:isurpass_smokedetector_00_000
2018-03-25 17:18:29.085 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:rcs_tz45_00_000
2018-03-25 17:18:29.087 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:innovus_smartpower_00_000
2018-03-25 17:18:29.088 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Checking zwave:innovus_smartpower_00_000
2018-03-25 17:18:29.091 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-03-25 17:18:29.098 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:36f5232f:node5' to inbox.
2018-03-25 17:18:29.099 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:36f5232f:node5' has been added.
2018-03-25 17:18:29.100 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
2018-03-25 17:18:29.101 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Setting controller into INCLUSION mode, highPower:true networkWide:true.
2018-03-25 17:18:29.109 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-03-25 17:18:29.109 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-03-25 17:18:29.112 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A C1 01 70
2018-03-25 17:18:29.114 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70
2018-03-25 17:18:29.120 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2
2018-03-25 17:18:29.123 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-03-25 17:18:29.126 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 01 00 00 B2
2018-03-25 17:18:29.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2
2018-03-25 17:18:29.131 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2018-03-25 17:18:29.134 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Learn ready.
2018-03-25 17:18:29.136 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2018-03-25 17:18:29.140 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@184581
2018-03-25 17:18:29.140 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
2018-03-25 17:18:29.144 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2018-03-25 17:18:29.146 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
2018-03-25 17:18:29.148 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-03-25 17:18:29.151 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 35ms/140ms.
2018-03-25 17:18:35.906 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:36f5232f:node5' has been removed.
2018-03-25 17:18:35.910 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=365, service.bundleid=234, service.scope=singleton} - org.openhab.binding.zwave
2018-03-25 17:18:35.928 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-03-25 17:18:35.939 [hingStatusInfoChangedEvent] - 'zwave:device:36f5232f:node5' changed from UNINITIALIZED to INITIALIZING
2018-03-25 17:18:35.943 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: MANUFACTURER not set
2018-03-25 17:18:35.945 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller status changed to ONLINE.
2018-03-25 17:18:35.946 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Controller is ONLINE. Starting device initialisation.
2018-03-25 17:18:35.950 [hingStatusInfoChangedEvent] - 'zwave:device:36f5232f:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-03-25 17:18:35.957 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating node properties.
2018-03-25 17:18:35.959 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating node properties. MAN=2147483647
2018-03-25 17:18:35.960 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Initialising Thing Node...
2018-03-25 17:18:35.962 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2018-03-25 17:18:35.962 [hingStatusInfoChangedEvent] - 'zwave:device:36f5232f:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-03-25 17:18:35.969 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:36f5232f:node5' has been updated.
2018-03-25 17:18:37.558 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 10 05 09 71 05 00 00 00 FF 07 08 00 6C
2018-03-25 17:18:37.563 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-03-25 17:18:37.566 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 10 05 09 71 05 00 00 00 FF 07 08 00 6C
2018-03-25 17:18:37.571 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 10 05 09 71 05 00 00 00 FF 07 08 00 6C
2018-03-25 17:18:37.575 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 05 09 71 05 00 00 00 FF 07 08 00
2018-03-25 17:18:37.578 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DETAILS)
2018-03-25 17:18:37.582 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class ALARM
2018-03-25 17:18:37.585 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Received ALARM command V0
2018-03-25 17:18:37.588 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Process NOTIFICATION_REPORT V0
2018-03-25 17:18:37.591 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 0 = 0, event=8, status=255
2018-03-25 17:18:37.593 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (0)
2018-03-25 17:18:37.596 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2018-03-25 17:18:37.600 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-03-25 17:18:37.602 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2018-03-25 17:18:37.606 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
…and I get that the device hasn’t been fully included, but after trying everything I’ve found online, no luck.
Has anyone had any success with this combination (Aeotec Z-Stick + Dome motion sensor)? Or could someone point me in the right direction? I feel like I’ve exhausted Google at this point.
