trollmar1
(Sebastian)
April 15, 2018, 11:19am
#1
I have a Problem to get my contacts via MQTT to be displayed is BasicUi.
Here is my item
Contact Wohnzimmer_TerassentuerAufZU "Wohnzimmer Terassentür" {mqtt="<[mosquitto:edomi/out/status/Wohnzimmer/Reed/TerassentuerAufZU:state:MAP(contact.map)]"}
The contact sends 1 or 0
Here is my transformation “contact.map”
0=CLOSED
1=OPEN
Here is my sitemap string
Text item=Wohnzimmer_TerassentuerAufZU label="Terassentür [%s]" icon="door"
My Problem is that only get “CLOSED” in BasicUI
If i send “1” the state dosen’t update or displayed in Basic UI.
Please any Idear?
trollmar1
(Sebastian)
April 15, 2018, 3:27pm
#2
I can say that it not a sitemap problem.
The rest api also dosen’t update.
So my mqtt item config with map is the problem.
Any idear how to change it?
Here a few questions that hopefully may help isolate your problem:
did the MQTT binding start correctly and established a connection to your broker (log-files will indicate this)
using MQTT-spy or similar, does the sensor post the expected updates to MQTT
are the topics to which the sensor posts and the subscription of the item identical
if the item is re-defined as a string or number item and no maps are used, does it indicate the expected value (0 or 1)
trollmar1
(Sebastian)
April 15, 2018, 4:10pm
#4
H lipp_markus
thx for help!
Yes mqtt ist working.
I trigger not with the real sensor. I use MQTT.fx to publish the payload
But your tipp was good.
When i change the item to “String” the mapping works as aspected. Number dosent worked.
Find out via RestApi
The question ist now:
How do I deal with this in the sitemap for basicUI
vzorglub
(Vincent Regaud)
April 15, 2018, 4:12pm
#5
Are you sure there are no stray spaces at the end of your lines in the mapping file?
