The only thing I can think of is possibly this -:
I’ll take a look.
I’ll take a look.
The change looks good, but there’s one thing I’m a little confused about.
The sensor_door
channel is defined as type Contact
, and I have my item defined as a Contact
as well. And I see you’re setting OPEN/CLOSED in the code. But when I look at the event log, I see the item changing between ON and OFF.
Is this the expected behavior?
Contact Door_Sensor "Door Sensor [%s]" { channel="zwave:device:zstick:node94:sensor_door"}
2018-10-20 07:22:28.360 [vent.ItemStateChangedEvent] - DoorSensor changed from OFF to ON
2018-10-20 07:22:37.450 [vent.ItemStateChangedEvent] - DoorSensor changed from ON to OFF
No, and in my tests it was open/closed… Can you check the log - there’s not a lot logged, but there should be this message -:
logger.debug("NODE {}: Handle door lock event {} endpoint {}", event.getNodeId(), event.getType());
It should be there twice with different event types - it would be interesting to check this… The code can really only return open/closed for this channel…
One other thing - are you able to differentiate between the lock state and door state? eg can you lock the door with it open, and ensure the door_sensor
channel still shows open?
Good point. I’ll try that.
I see this in the log. You’re missing an argument in your log statement.
2018-10-20 07:22:37.599 [DEBUG] [ng.zwave.internal.converter.ZWaveDoorLockConverter] - NODE 94: Handle door lock event DOOR_LOCK_STATE endpoint {}
2018-10-20 07:22:37.599 [DEBUG] [ng.zwave.internal.converter.ZWaveDoorLockConverter] - NODE 94: Handle door lock event DOOR_CONDITION endpoint {}
Thanks. I’ll remove the “endpoint {}” part - it’s not needed.
In any case, this shows both reports - I can’t see how to get an ON/OFF with door_sensor
as the channel
Are there state updates also logged between these messages?
Here’s the full log. You’re clearly setting OPEN/CLOSED.
2018-10-20 07:22:37.598 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 94: Incoming command class COMMAND_CLASS_DOOR_LOCK, endpoint 0
2018-10-20 07:22:37.598 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 94: Received COMMAND_CLASS_DOOR_LOCK V1 DOOR_LOCK_REPORT
2018-10-20 07:22:37.598 [DEBUG] [al.protocol.commandclass.ZWaveDoorLockCommandClass] - NODE 94: Door-Lock state report - lockState=Unsecured, handlesMode=1, doorCondition=3, timeoutMinutes=254, timeoutSeconds=254
2018-10-20 07:22:37.599 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 94: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-10-20 07:22:37.599 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 94: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_DOOR_LOCK, value = 0
2018-10-20 07:22:37.599 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 94: Updating channel state zwave:device:zstick:node94:lock_door to OFF [OnOffType]
2018-10-20 07:22:37.599 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 94: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_DOOR_LOCK, value = 3
2018-10-20 07:22:37.599 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 94: Updating channel state zwave:device:zstick:node94:sensor_door to CLOSED [OpenClosedType]
Interesting. I’m not sure what’s changing this then, but it’s not the binding
I think that this is probably ok then and I can probably merge this (I’ll fix the log message)?
Me either. But I’ll look into it more closely.
Yes, this is working as expected.
Yep.
Thanks.
I’ll bet this is it. When you set the Thing online without a detailed status, it cleared out whatever detailed status might’ve been set (e.g. Request NIF). By removing that updateStatus call, the detailed status is not cleared.
Yep - I’ll make a change in this PR that will hopefully fix it. I’ll just add an update status in the Done state - that ought to sort it out (should really have been there anyway I think).
Ok, nevermind, it’s reporting OPEN/CLOSED just fine. It was my brain that was not working correctly this morning.
Confirming that this fixed the issue with the “Request NIF” node status not being cleared after initialization completes.
Thanks!!!
