In HABpanel, use an Image widget. Then configure the widget with an item that’s linked to one of the image channels – image, doobellImage, motionImage, etc.
For the image channel, you need to enable image refresh. The doorbell and motion image channels will be updated when one of those events occurs.
I’m looking to display the history of the last visitor. Right now I do this via a script. I have the channels linked. Ill hunt the forum for some sample Angular code
Cool. Using an Image Item in HabPanel is fine, I can get the doorbellImage to work, it’s just extracting the code from it to put into my existing Widget
Ill play around! So far so good! PS: SIP is another one for your list along with RFID, I have this working also via a script.
Thanks Mark, got the Last Pressed working nicely. Hopefully someone smarter than me will provide an example using the History, it would be nice to see a few small images of the past 2 visitors. Ill play around when ive got some more time but awesome work!
re: SIP, how it works for me, is theres a rule that switches a virtual item on
DoorBird_SIP
When that switches on, I do this:
rule "Send request for DoorBird back call"
Item DoorBird_SIP received command ON
sendHttpGetRequest("http://user:pass@192.168.0.141/bha-api/sip.cgi?action=makecall&url=sip:1002@192.168.0.6")
logInfo("DoorBird", "SIP Call from Doorbird")
rule "Send request for DoorBird hangup"
Item DoorBird_SIP received command OFF
sendHttpGetRequest("http://user:pass@192.168.0.141/bha-api/sip.cgi?action=hangup")
These effectively allow me to call the gate and then hangup.
@mhilbush
Yes it is great to see another binding for cameras, the more support and options people have the better. Since I do not own a Doorbird I have zero drive to ever implement the SIP or some of the other stuff in the API, so having a dedicated binding is fantastic. If you ever wish to add the ffmpeg features to your binding it is pretty easy to paste across as it does not rely on Netty like most of my coding and I have been cleaning up the code to make it neater and it has zero dependencies. Well you do need to manually install ffmpeg for it to work.
Placing the animated gif into the …conf/html/ folder then allows it to be used in sitemaps and the like.
@dastrix80@swamiller Here’s how I was thinking about handling this. Let me know what you think.
The idea is to create a montage of the last n history images for the doorbell and motion sensor. So, there would be two new channels
doorbellMontage
motionMontage
In the thing config you would specify two parameters
the number of history images to include in the montage (1 to n, where n should be kept relatively small, e.g. 3, 4, or 5). It needs to be a small number because each history image needs to be pulled from the cloud service through the doorbird. This would take a while for more than a few images.
the scaling factor for the image (i.e. percentage between 1 and 100)
Whenever, the doorbell is pressed, or motion is detected, not only would the doorbelImage and motionImage channels be updated, respectively, but the doorbellMontage and motionMontage image channels also would be updated, as well.
It would look something like this (4 images at 20% scale).
Right now, the images are concatenated horizontally, but vertically is equally easy, and could be configurable either way.
Hi Mark, sorry for the slow reply. This is a fantastic idea. I would never use the motion version but I would totally use the Visitor version. Horizontal for me is great! I use 250x200 resolution now for the ButtonPressed channel if that helps with your scaling/sizing.
Ok, I’ll post a new version shortly. You’ll need to delete and readd the thing to pick up the new channels. You’ll need to experiment with the scaling factor to get the right size that meets your needs.
As a reference, the 30% setting produced a 5-image wide montage that’s 960x144 pixels.
Hold off on downloading the latest version. I forgot to add the new montage channels to the D210x thing. I need to fix that. I also need to rework a couple things. I’ll post back here when it’s ready.
Hi Mark, ive installed and configured it. Is there a way to trigger the doorbell so that it records an image without using the image channels? ie: simulate a button press. Setting Doorbell_Pressed does not take the history Image
