From what testing I can do here, this does seem to be z-wave related. The only other controllable device I have are some hue bulbs through a hub, and they are working normally. I can also reproduce this right from the osgi> prompt by sending ON/OFF commands to z-wave devices.
If it’s a zwave problem, can you provide the log then? I’m not sure that anything has changed that should cause messages to be processed twice, but the log might help to see…
Had a few more minutes to play around. I am noticing only a single event hitting the API, so it is more like it is logging it 2x, so I looked at the logback config, and noticed it was full of ^M line endings now. I had not seen that before, so s/^M//g and restarted. Unfortunately it did not make any difference, but I thought this was interesting. There is nothing special about my install that I am aware of. I remove all addons and such before dropping new ones in, all done with a script for the last 6 months. I ran it again on today’s build, full restart, and still see it in the console and log twice for z-wave events. The hue continues to ouput 1 line per event.
I will try to get a log file off to you before I need to go.
Thanks Jim - got the log - as you say, nothing out of the ordinary there… See how it goes with your tests - if it continues, you could try changing to TRACE logging in the zwave binding and that should log a bit more about the eventing (I think ).
