I’m really annoyed from using v2.5.3. Especially the ZWave binding doesn’t seem to work as expected. There must be an error because I can’t edit ANY ZWave thing I added from the inbox. I always get the error message “Error 500: Internal Server error”.
This was different in v2.5.1 so I hope after downgrade the ZWave binding will work again as expected - it can*t get worse…
So does anyone can provide me a download link where I can download a Linux installation package (.deb)?
My system configuration is:
Raspberry Pi4
openhabian based on Buster
The ZWave binding in 2.5.3 is unchanged vs. 2.5.1 and absolutely fine, your problem is elsewhere.
That is, you don’t want to downgrade but you need to debug your system.
Try clearing the cache, eventually openhab-cli reset-ownership, check jsondb file permissions (writable?), eventually reinstall your current packages (apt-get install --reinstall openhab2 openhab2-addons openhab2-addons-legacy), check this thread and enable debugging if all of that didn’t help.
I set the loglevel of org.glassfish.jersey.server as you suggested, but there are no results shown neither in the openhab.log nor in the events.log when setting the filter to one of the following:
glassfish
jersey
server
Is this an indication for that org.glassfish.jersey.server doesn’t cause the error “500: Internal Server Error”?
Hello Markus,
I did all the steps you suggested, but the misbehavior is still there.
The strange thing is that the “Error 500: Internal Server Error” only occurs when trying to edit ZWave thing. All other things can be edited without error.
Unfortunately I can’t upload the screen videos I made to show my problem…
And in the log files openhab.log and events.log I can’t find any hint to the Error 500
Your zwave controller thing may be wrong (correct serial interface?) or your jsondb might even be corrupted. You can edit that manually (OH has to be down).
Hello Markus,
I think, the controller thing is ok because I can add thing, assign item to their channels and they are working.
But I have another problem which may be has an impact to this problem. Please see this link: ZWave: two serial controllers although only one is connected
Could this be solved by editing the jsondb? And where do I find that database?
Probably a good idea to start from scratch. jsondb is where OH stores what you click in PaperUI. /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.Thing.json
Try just log:tail and then edit one of your Z-Wave Things to reproduce the error.
Have you tried deleting (not excluding) and rediscovering your Z-Wave Things? I agree that the issue is not with the binding itself, but somewhere else in your configuration.
I did as you suggested. But there where no error entries in the log although I could reproduce the error…
And yes:
I deleted and rediscovered the ZWave things. And after adding the rediscovered things the behaviour was the same as before: No editing possible.
Even after hard resetting the ZWave-Dongle every thing I added wasn’t editable…
How many ZWave devices do you have? Did you delete all the things, then add them all again and then try and edit one? Or did you delete all of them, add one back and try and edit it one at a time? It might be possible that there’s one thing that is causing the problem. If you add the things back one at a time and test at each step it would help determine which thing causes the error.
I appreciate that this can be a lot of work.
Do you have any ZWave things created in files or was everything created with the PaperUI?
