Download installation files from webpage not working
i have issue with download any distro installation files from general public webpage. I tried to download instalaltion file for windows, but category setting doesn’t switches my choise in download section in link https://www.openhab.org/download/.
I tried several browsers, netwokr providers.
Can you test download any installation files instead default (Linux) download webpage please?
I just downloaded 2.5.2 for Windows & unzipped successfully.
This should be a direct link.
https://bintray.com/openhab/mvn/download_file?file_path=org%2Fopenhab%2Fdistro%2Fopenhab%2F2.5.2%2Fopenhab-2.5.2.zip
Huuh? Agreed?!
Google Chrome 87.122 (Official Build) (64-Bit) on Arch Linux 64x here.
If I visit the mentioned download page, I can not select anything else then Linux.
Notification for @ysc.
Confirmed, thanks. Will be fixed ASAP, in the meantime use the direct link above.
Sorry, I misunderstood. I downloaded from Windows 10.
Or hold on for 2.5.3 which should be out today.
hi i am also trying to download the openHAB software for Raspi since 2 days but i can’t select anything! Really frustrating
I can confirm the links for Pi & Windows, at least appear to be broken for 2.5.3 For the Pi, I would follow the Linux install instructions for openHABian. That is what i use on my Pi when I am testing openHAB.
Other Linux Systems (add openHABian just like any other software)
openHABian also supports general Debian/Ubuntu based systems on different platforms. Starting with a fresh installation of your operating system, install git, then clone the openHABian project and finally execute the openHABian configuration tool:
# install git
sudo apt-get update
sudo apt-get install git
# download and link
sudo git clone https://github.com/openhab/openhabian.git /opt/openhabian
sudo ln -s /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config
# execute
sudo openhabian-config
You’ll see the openHABian configuration menu and can now select all desired actions. The “Manual/Fresh Setup” submenu entry is the right place for you. Execute all entries one after the other to get the full openHABian experience:
from https://www.openhab.org/docs/installation/openhabian.html#other-linux-systems-add-openhabian-just-like-any-other-software
For windows, I think this is the direct 2.5.3 link.
https://bintray.com/openhab/mvn/download_file?file_path=org%2Fopenhab%2Fdistro%2Fopenhab%2F2.5.3%2Fopenhab-2.5.3.zip
