Platform information:
- Hardware: Raspberry Pi 3B
- OS: OpenHABian (latest version)
- openHAB version: 2
Trying to install Samba Cloud when this happens:
[17:36:22] root@HomeAutomationSystem:~# sudo apt-get install samba samba-common-bin
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
[17:37:56] root@HomeAutomationSystem:~# sudo dpkg --configure -a
dpkg: error processing package openhab2 (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
Errors were encountered while processing:
openhab2
Anyone got a solution?
I don’t want to uninstall and reinstall OpenHAB as I have seen on Google as I don’t want to lose my configuration and have to redo it.
Thanks for your time in advance.
