Hi, I am new to openhab so please excuse my ignorance.
I have an openhab test installation on a raspberry Pi, using the z-wave binding. There are only two nodes on the network. Node 1 is a Z-Wave.Me ZME_UZB1 USB Stick and Node 3 is a Dragontech WD-100 in wall dimmer.
The WD-100 item is configured as follows:
Dimmer Dimmer1 “Test Dimmer [%d %%]” { zwave=“3:command=switch_multilevel” }
My default sitemap is a very simple one:
sitemap test label=“Main Menu”
Frame {
Text label=“Items Under Test” icon="house"
Frame {
Slider item=Dimmer1 label=“Dimmer1 [%d %%]” icon=“slider” switchSupport
So, when a click the up arrow once, the light turns on (100%). When I click the down arrow once, the light turns off (0%). So far so good.
However, when the light is off, and I click and hold the up arrow the dimmer increases to just the first level (5%) and no more. When the light is on (100%) and I click and hold the down arrow; however briefly, it always dims all the way down to 0%.
Can somebody please tell me what am I doing wrong?
P.D. I also have openzwave control panel in the pi. So, I stop openhab, and start openzwavecontrolpanel. The dimmer works as expected with openzwavecontrolpanel.
